Plows: Moldboard vs Disc vs Chisel vs Other
   / Plows: Moldboard vs Disc vs Chisel vs Other #1
datanull
Montgomery Co. Arkansas, 34.357183,-93.67085
2008 Massey Ferguson 1540
I want to be able to prepare a few acres of ground for a variety of uses, for example:
1) garden, yearly, where I think I would plow first pickup rocks and use small tiller to prepare seed beds.
2) plant tree seedlings.
3) plant tree seeds.
4) other one time plowing for as yet to be determined plant species.
My soil is somewhat rocky and I would describe the soil type as clay. Some sandy soils as you get close to the `river'
Currently planted with Bermuda grass (hay/pasture) and a few weeds.
At first I think I need a 12-14 inch 2 bottom moldboard but before I start spending any money I think I need to collect more data. Hopefully I have provided enough information, about task and soil conditions.
   / Plows: Moldboard vs Disc vs Chisel vs Other #2
Just saw your post.
Depending on your tractor, 2 bottom is probably a good choice. In heavy rocky soil it's a good idea to have 15-20 hp per 14 inch bottom, especially if the land is steep or wet. A light tractor might be helped by using tire chains. To plow small plots, a bigger plow will be too cumbersome and not save much time. Also, in small plots a mounted plow is much handier than a trailer. If your land is steep, I'd consider a rollover (2-way) plow. More expensive to buy but your wear parts (shins, points etc.) will last twice as long. Happy plowing.
   / Plows: Moldboard vs Disc vs Chisel vs Other #3
What model tractor are we using for this?
How many acres will you be plowing?
   / Plows: Moldboard vs Disc vs Chisel vs Other #4
Clay tells me that your soils need help. I don't think you can change them in a short time but my recommandations would be for the chisel plow to enhance drainage as well as root gowth and more plant decomposition in the growth zone. The final tillage could be done with a tiller or lighter disc type machine although your goal would be to stay away from compacting.
If you do go with a moldboard you could use a three bottom with your tractor. With clay you will find that you can't move it fast, maybe four miles an hour max!
   / Plows: Moldboard vs Disc vs Chisel vs Other #5
For just a few acres go with a rota tiller. Then you will only need the one implement.:D
   / Plows: Moldboard vs Disc vs Chisel vs Other #6
Moldboard plows work well, as long as they are setup correctly to your tractor, if not they can mess up a field quick. A chisel plow would probably be the fastest and then follow up with disc. Not sure what hp your tractor is but smaller chisel plows may be hard to find.
Just saw your post.
I had "decided" on a moldboard plow but realized that I very little data to base my decision on. I do believe a 2-bottom moldboard will be best suited to my needs.
Thanks for your input.
I was under the impression that a chisel plow would require more HP than my 40. I thought it was about 10hp per chisel point.
I was looking around at my dealers on Sunday,(they were closed). They had a few chisel plows but no moldboards that I could see. Perhaps in my area chisel plows are used more than moldboards.
I don't know about the rocks. Every now and then I come across a rock that seems big enough to do some damage to a tiller, and I have'nt done much digging.
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
207271 (A52708)
207271 (A52708)
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A59230)
2023 Chevrolet...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
