Slow FEL Dump (Help)
   / Slow FEL Dump (Help) #1
Charlton John
Gold Member
North East New York
Kubota B2620
I have a couple questions I am hoping you can help me w/. On my loader when dumping it is moving extremely slow. This is happening w/ or w/o anything in the bucket. I also when dumping hear the engine kind of whine a little or working extra hard to get through the dump motion. All other motions on the loader are working at normal speed w/ no ecssesive engine strain. All hydrolic hoses are snug, I am full of hydro fluid and loader has been greased every 10 hrs. Any suggestions? Also not sure if this is normal please advise when the tractor is on or off there is some wiggle to the loader joystick, not much but it appears to move some at the housing where it hooks up. I checked the 3 or 4 visable nuts that appear to be holding it and they are all tight. Thanks!
   / Slow FEL Dump (Help) #2
First off, are you running @ idle or are you reving it up a but. If @ idle, it would be slower.
Second, I'm not sure if it is like my 3400, but I have two dump selections. Kinda like the thw selections you have when lowering the bucket, first step is a power down (where hydraulic pressure is applied to force the bucket down, and even raise the front of the tractor), second is float, where no pressure is applied and gravity lowers the bucket. If you push it into float with the bucket elevated, you will heare a whining sould as it is (forcing) the hyd fluid out of the cyl.
The dump on mine is the same way. 2 position, 1 is forced dump and the other is like a float. With an empty bucket, and in the second position, it will dump much slower than the forced dump. And you will also get that whining sound too. Could thins be what you are thinking is "engine bogging down"??
If not then maybe something is bent of tweaked. does it curl ok?
Thanks LD1 Yes I did check the operation in both low idle and normal operating speed to the same result. The curl is fine and up and down on the actuall loader is fine just seems the dump is very slow. I was moving some dirt this weekend which made me notice when dumping the materiel it seems as if it was taking forever. So I checked again yesterday w/ no load in the bucket and it seems the same way very slow. Normally when operating around 2k rpm's I can dump the bucket all the way till the end to clean out any stuck material still in the bucket and "bang it a couple times" yesterday w/ no load I couldnt really accomplish this.
   / Slow FEL Dump (Help) #4
Is the joystick "lock" partially engaged. I have 2 little kids and when I need to leave the loader off the ground while working I always lock the joystick. This past weekend I noticed the loader not working properly, and it turns out the lock was partially engaged.
If that is not it does the machine lose power when you turn the steering steering or driving up a hill. Perhaps one of the dual hydraulic pumps is not working properly. I'll be watching this one!
   / Slow FEL Dump (Help) #5
I get a whine when using my B2620 loader but haven't pinned down exactly what causes it. My traded in BX 1800 was very smooth and noise free in loader use so this is worrysome. Frankly the loader on my B2620 doesn't seem as good in many ways as the loader on my BX.
   / Slow FEL Dump (Help) #6
Since it seems like you've eliminated all of the silly possibilities (like accidentally being in float mode), my thought is that you've got something wrong with the valve at the joystick. One way you could verify this would be to swap the quick-connect hoses that go to the curl/dump hydraulics where they connect to the joystick. That should reverse the action of the bucket relative to the joystick motion (i.e. left now dumps and right now curls). My hunch is that the bucket will now dump at normal speed but curl very slowly. If so, the problem is clearly with the valve/joystick assembly.
Given that the engine is bogging down when you try to dump (probably similarly to the way it does if you raise/lower/curl the bucket all the way to the end and continue asking for more), it sounds like the hydraulic fluid is being significantly obstructed from flowing into the bucket-dump hydraulic hose.
If you try my little experiment, let us know what you find out.
   / Slow FEL Dump (Help) #7
When dumping you move the handle to the right.If you move the handle further to the right past the detent,the dump function slows.This is the controlled dump as the regenerative function comes into play.Could this be what you're finding?Not sure about the change in engine sound.Good Luck.
   / Slow FEL Dump (Help) #8
I'd do what jcaron2 said and see what happens this will narrow it down. It sounds to me like it's in the control valve too.
   / Slow FEL Dump (Help) #9
the only time i get a whine's or the buckit acts funny is when my 3-piont hitch handle
is left in the up or down spot
Thanks Guys. I am going to try what JCARON2 suggested an d see what happens. I just had a big pile of mulch delivered yesterday so I have some materal to work w/ this evenening. I will keep you all posted Thanks again!
Just an update. Not sure if this is your problem, too Bill. My dealer just got back in touch w/ me (who is great by the way) and said it sounds as if your 3ph control knob (right below the seat) is in the almost closed position to open it up fully and then try the loader again. Well he is correct to say that the knob is just about in the closed position as I usually leave it there and have been using the Box Blade so I like to keep it there to slow down the lowering of the blade so maybe this is my problem. I didnt know the 3ph control knob affected the loader operation but according to him apparently it does. I will have to try this tonight as well.
   / Slow FEL Dump (Help) #13
CJ, I share your confusion that the 3PH control knob would affect loader operation. I'm not sure on your tractor, but on my MX5000 there's a similar valve to control hydraulic flow to the FEL. It's on the lower right side of the tractor near the hydraulic oil filter, and it's made to be turned with a screw-driver. My FEL was getting really sluggish a while back and after checking I found that that valve had inadvertently become almost entirely closed. However, it controls fluid flow to the entire FEL assembly, so a closure there should manifest itself in ALL of the FEL movements, not just dumping.
Keep us posted, and good luck. I'm not sure if you've ever connected/disconnect hydraulic lines with quick couplers before, but it's pretty much like an air compressor hose. It's pretty normal to leak a few teaspoons of fluid as you do it, so don't be alarmed if that happens.
Josh
Thanks Jcaron2, Yes on my first tractor I used to remove the FEL to mow so I have unhooked the lines before. I will try this 3ph contral knob first and then your idea of switching lines to see if there is a difference if I need too. I will update tonight or tomorrow Thanks again!
   / Slow FEL Dump (Help) #15
I hope you find the problem, but I sure hope that's not the cause.
I have my 3 ph control knob almost closed too for box blade and FEL seems to dump fine. I'll play with it this weekend and close it completely and see if it effects FEL.
   / Slow FEL Dump (Help) #16
On my B200 I had the exact same problem. It turned out that once I lifted the rubber boot covering the linkage and removed the main operating lever (joystick) there was a circular plate connected via 3 rod ends to the individual valve spools. Well, the bolt between the plate and the rod end for the bucket curl had worked loose. When the joy stick was pushed to the left it pushed down, thus the loose bolt made no difference. But when moved to the right, the slop resulted in the solenoid just being cracked open and slow.
Re-torqued the bolts and now it is back to normal.
Update. I tried the 3ph controll knob as suggested by my dealer, didnt really see any difference. In playing w/ the joystick as # 2 suggested I did see a pretty substantial difference in speed. When passing the detent it is slow but if I stop the joystick right before it seems to dump normall but the only problem w/ this is there is such a fine line from detent to non-detent that it seems to be like a 1/4 of an inch or less that I have before it passes the detent and slows down. Is this normal? I will be using the loader all weekend moving my 10 yrds. of mulch around so we will see what happens I will update. If no better I will try some of the other suggestions w/ hoses and removing the joystick. Thanks guys!
   / Slow FEL Dump (Help) #18
It sounds like an issue with the joystick valves (since you can get it to work when you baby it). Hopefully just an adjustment or something loose as suggested.
Well it turns out dealer was most likely right after all. In putting some hrs. in this weekend moving mulch and boulders around I worked all weekend w/ the 3pt. control knob fully open and the loader worked a lot better. I was very suprised when he told me this may be the problem I tried it the other night only for a minute or 2 and didnt see the difference but after putting some series seat time in this weekend I can deffinitly see the difference so problem solved. Thanks guys for the suggestions.
   / Slow FEL Dump (Help) #20
I played around with this on my B2320 this weekend and it made absolutely no difference with 3pt adjustment fully closed and fully open (at idle or high rpm).
Not sure of the 23 or the gear drive setup is different.
Freighliner Tender Truck (A61306)
Freighliner Tender...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A60429)
2019 CATERPILLAR...
KUBOTA SVL75-2 SKID STEER (A60429)
KUBOTA SVL75-2...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
