newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,119
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
Backhoes alsobox blade is even better/more useful counterweight
A carry-all is $100 cheaper than a ballast box.. And it still has other uses, unlike the ballast box. If you need ballast, buy the carry-all. But if you have extra money to throw away, by all means, throw it away...
Go to buy youself 2 wratcheted heavy lift tie down straps (about $18 per strap from True Value). Run the straps through the 3 point lift gates on the implement, put the FEL over the implement and attach run the straps over the FEL and then wratchet it up. You want it so that the implement is suspended by about a foot under the FEL.
Alright so lets see, here's two carry-all's that came up under a google search. The first one made by Farm Pro for $110, Farm Pro 3 Point Carry All Fork Tractor Attachment NEW - Denham Springs - Bonanzle.
And the second made by Sundowner which is on Ebay for $148, Sundowner Carry-All Platform Tractor Attachment - eBay (item 260407666984 end time Sep-06-09 08:04:00 PDT).
Now, are the prices cheaper? Mmm, yeah, by about $100 bucks. But, lets take a look at the weight capacities. The Farm Pro is only rated to hold 400lbs, which is pretty useless for ballast. Not to mention you can get that much in just your rear tires alone with Rim Guard. The Sundowner on ebay is built almost exactly the same and if you could find the specs for it, I would bet that the weight it's rated for is close to the same as the first one.
A ballast box will run you $206 at a dealer, give or take for mark up or what he may discount you, (and that's not even $100 more, only $94 and $58). The real seller though is that on the ballast box, it's built to hold a lot of weight. It'll easily carry double what either of those carry-all's will, and like I said, if you get fork's than there's no point for a carry-all.
"But if you have extra money to throw away, by all means, throw it away..."![]()
Pallet forks are nice to have, but a toothbar and the bucket edge under the edge of the pallet might be enough.
Then a ratchet strap around the item and whatever appropriate cross tube between your loader arms should do it.
DO be sure to tip it back towards you a bit before tightening the strap, if you lower it and then tip the bucket back your strap will get loose.
Do have the truck drive out from under your bucket, then LOWER ( don't DROP) it slowly.
