WH401
Platinum Member
Looks like the lift capacities of my JD 3038E with a 305 loader are well within the limits of what I'll need to unload:
Measured at pivot (U) 1186 (539)
Measured at pivot (W) 1294 (588)
At maximum height (VV) 1433 (639)
At 1.5 m (59-in.) lift height (XX) 1814 (809)
At ground level line (ZZ) 1422 (634)
The attachments that I'm looking at are the 73" Caroni Flail at 650 lbs and the Wallenstein BX42 at 425 lbs.
I don't have any hooks on my loader for attaching chains. I may look at getting a set of forks for the FEL and I think that I'll get the 3PH frame from TSC and make a box for adding weight in the back.
Hopefully after a few more hours on the tractor I'll be ready for the next step. I will request a truck with a lift gate when I order.
Thanks to everyone for the quick response.
Dennis
I don;t have any
You won't have a problem lifting the implements, your problem will be how to lift them. As you said, with no hooks on the FEL bucket, pallet forks will be your best friend. I ordered forks with my 3320, even though in the past I have always used angle iron attached to the FEL with bolts. So far the pallet forks have been worth their weight in gold, and they're almost a necessity with an FEL tractor. Skip the 3pt frame from TSC and go right to your Deere dealer and order a ballast box, there only $206 and that's a lot easier than try to make one.
