dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,674
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Wow, getting those brake levers off was tough!
I have a pretty good selection of gear pullers, but none would do the job.
I tried heating with a torch, soaking overnight with LiquidWrench under
puller tension. No dice. My final choices were to weld some ears onto
the lever tube (for better gear puller grab), or to drill holes and use bolts.
In the first photo, I drilled and tapped for some bolts. In the second, I did
the other side by drilling for bigger bolts, and using nuts.
The third photo gives you some idea of the pressure put on the brake shaft.
Both the shaft and my puller use hardened steel....it seems the puller bolt
was just a bit harder.
Why were my levers so much harder than Kyle's to remove? I can see that
the lever tubing has rusted just a bit inside. My roll pins, BTW, are made of
a single piece of steel, rolled up in a double-thick spiral. They were a bit
rusty, too. None of this rust was visible externally.
