Deere 6400 Lost all Hydraulics Except PTO
   / Deere 6400 Lost all Hydraulics Except PTO
i ordered the guage that was suggested, so i don't know the pressure yet.
I have checked all the valves on the bottom of the housing. the only one that wouldn't come out freely is the pressure regulating valve. it hangs just before it would come out.
The tech manual shows that the steering and hitch get fluid from the piority valve. Is this the valve on the back of the tractor. How does valve work?
Update: I have no pressure on the priority valve DR. The hose that goes down into the pto housing below the pirority valve on the rear of the tractor came loose and shot fluide out. This tells me the pump is pumping but I don't know how much? Any ideas from this info?
Finally got my guages. I don't have any pressure at the hyraulic test port on the main pump. I don't have a test port on the filter. Is there a way to check pressure from the charge pump? What would cause the main pump not to have any pressure?
   / Deere 6400 Lost all Hydraulics Except PTO #15
On the filter test point, you shoud not get more than 20 or 30 psi, as it is usually in the suction line or the return line. Some filters have a built in gage.
Yes, you should be able to measure the pressure on the charge pump, it usually is low, around 300- 400 psi. What so you consider the main pump? If you are talking gear pump, you can put a pressure gage in the pump out circuit, before any other valve.
Keep in mind, hyd fluid doesn't have much pressure unless it is pushing on something. If a valve is in the neutral position, the fluid is recirculating from pump to tank. To check cylinder relief pressure, hold the valve lever in the forward position until the cylinder extends and goes into relief.
   / Deere 6400 Lost all Hydraulics Except PTO #16
I take it your JD is a closed system with a front mount pump and a charge pump in the belly check priority valve do you have a solenoid on the front pump?
BTW do you have brakes?
   / Deere 6400 Lost all Hydraulics Except PTO #17
russhog
Do you have one of these transmission? You mentioned charge pump, so that tells me you have a hydrostatic transmission.
A priority valve is just that, it will give priority to the circuit that is critical for safe operation, such as steering over any other function. It probably has a relief valve. To check the pressure on the priority valve, put a gage at the input of the priority valve, and turn the steering wheel, or activate the other function that is in the circuit.
JD6400
Transmission:
Transmission: SyncroPlus
Forward: 12
Reverse: 4
Oil capacity: -unknown-
Comments: Standard transmission
Transmission:
Transmission: PowrQuad
Forward: 16
Reverse: 12
   / Deere 6400 Lost all Hydraulics Except PTO #18
The fluid is picked up in the belly with a long metal tube with O rings as a seal but you said that you had pressure at priority valve the priority valve is probably dumping back to sump might be dirt in piston bore or broken spring Do not run the tractor for any amount of time or you will cook the front pump.
   / Deere 6400 Lost all Hydraulics Except PTO #19
He said he had no pressure at the priority valve. Post #13
   / Deere 6400 Lost all Hydraulics Except PTO #20
He has fluid it's not going to the front pump its being diverted to sump.
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
