What would you change about your current John Deere tractor?
   / What would you change about your current John Deere tractor? #114
How about pink wheels with purple bodywork and brown where black currently is used? :rolleyes:
I was thinking midnight black all the way around. Maybe with just a little orange in celebration of the evil holiday to come!
J
   / What would you change about your current John Deere tractor? #115
J
And then red & green at Christmas, pastels at Easter. :rolleyes:
   / What would you change about your current John Deere tractor? #116
JD 2520 here -
I'd give it either a three-speed transmission, or lower the gearing on the two-speed that's in it now. Also, needs the updated draft arms that clear the rear tires better, like what they're putting on the newer models.
A better seat, air-suspension or some such thing.
Built-in tool box somewhere on the tractor.
More/better ways to add ballast weight.
Options for top-n-tilt and for more hydraulic outlets on front or back.
Bigger cup holder.
My thoughts exactly, plus a factory cab option.
   / What would you change about your current John Deere tractor? #117
Green and Silver, Red and Gold,
and a story told of old ...
Peace and Love and Hope abide,
this Christmastide!
Joe
   / What would you change about your current John Deere tractor? #118
For the 2320 just having the 2520's hyd speed.. And do something with the cooling system to keep it from sucking the grill full of debris when mowing, our lawn is soo dry in the summer you have to stop every couple hours to clean the grill and check the rad screen. Maybe if the rad was behind the engine like in some other brands this wouldn't be as big of a problem, but then there would be a whole other set of issues probably. Leave everything else alone the tractor is a real sweetheart of a machine.
   / What would you change about your current John Deere tractor? #119
J
I don't know about the orange but one of the sexiest tractors Super Stock tractors that I've seen at the tractor pulls around here is a black Allis Chalmers. There is something nice about a black tractor or for that matter a car or truck, although it is nearly impossible to keep black vehicles clean.
   / What would you change about your current John Deere tractor? #120
We only have one Deere right now, a 455 L&G. I would give it a faster reverse, and some sort of way to tell when you're at 540rpm, even if it's just a light that turns on when you get there.
Kyle
This can be adjusted. Try lifting the fwd pedal with your toe and you will see the capability of reverse.
The fwd pedal can be extended and there is an adjustment that affects the pedal position. Adjust to raise the reverse pedal and extending the fwd pedal maintains fwd speed. OR just extend the pedal.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2019 Bobcat T590 (A50123)
2019 Bobcat T590...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2020 KENWORTH T680...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
