Shop Tricks
   / Shop Tricks #101
So you are saying I won't be able to buy new t12 ho bulbs in the future?
I just spent a few hundred bucks putting up 8ft fixtures in my garage:eek:
They are the quick start cold temp ones. They don't whine, but they do cause radio interference.
I saw the t8 fixtures when I bought the t12's. I had no idea they were planning on doing away with t12's:confused:
For cheap fluorescent bulb I buy the fleet electric brand form Home Depot. I have had them in my basement for the past six years with no problems. I also have them in all three of my garage door openers with no problems.
About the 5000k I was talking about is a light level scale not the temp of the sun. It refers to the whiteness of light. They are getting rid of the phrase warm light or cool light you used to see.
The new electronic ballast will cause interference. But they make a RF filter than you can install on the circuit and remove the static you hear. Also if your electrical system is not grounded properly it can cause noise on you electronic equipment.
Yes, you will not even be able to buy T12 lamps any more any ware curtsey of government energy standers.:(
   / Shop Tricks #102
These mini brushes from Harbor Freight are pretty good for small orifices.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Mini brushes specialized for cleaning the smallest areas, including tubing, spray guns, air caps, air passages, and fluid nozzles.
Brush sizes: 12mm, 20mm, 23mm, 25mm and 30mm; Length: 4"
Smallest is 12 MM (about 1/2 inch) I wonder what kind of a spray gun they clean with that. :confused:
Bruce
   / Shop Tricks #103
It would seem that Harbor freight got the numbers wrong in the description.
That is the set I bought, here is a pic.
   / Shop Tricks #104
Ken glad you caught that.Sounds like i could clean my chimney with the big ones lol
   / Shop Tricks #105
I'm sure everyone would like one of those TV show shops where everything is neatly hanging from a peg board. The trouble for guys in the secular world is the hook pulls out when you grab a wrench. I bet I poured six inches of concrete over a couple hundred hooks just to teach em!!
This can be ended with a glob of silicone caulk over the hook. I finally have that shop wall.
Kinda fun to actually put my tools away rather -than look for them.
   / Shop Tricks #106
bobodu, do you put the silicon glob on the end that goes in the pegboard or under the hook so it glues to the pegboard? :confused:
   / Shop Tricks #107
Hot-melt glue accomplishes the same thing.:)
   / Shop Tricks #108
>> DRILL PRESS TIPs <<
There are THREE holes around a keyed chuck for a reason.
There are also three "bit grippers" to match those three holes.
When chucking a bit, progressively tighten in ALL THREE HOLES, going from hole to hole, tightening a little more each time.
Doing thus, your bits will be held tighter and the chuck will last much longer.:cool:
When a chuck is so tight that you can't loosen it with the key, remove the bit from one of those 4-in-1 screw-drivers and use the hollow shaft for a "cheater bar".
Better yet, take some two-part plumber's epoxy stick and permanently afix the chuck-key into the shaft of the screw-driver that you already lost/broke the bit, thus making a nice chuck key with extra leverage.:)
To contain the mess when using cutting oil on the bit, put a block of wood for support, or the vise, inside a shallow card-board box on the drill-press table with the flaps standing up.
Crumple up plenty of old papers/rags inside the box to soak up the oil.
The box flaps will catch most of the sling-off and most of the oily shavings will fall into the box.;)
When drilling larger holes through steel, there is a point when the bit is almost through, when there is only a thin ring of material around the perimeter of the hole, that the bit starts violently grabbing.
Before breaking another bit, or getting knocked in the head when your project gets hurled at you by the spinning bit, STOP RIGHT THERE and quit drilling.
Put the work-piece in the vise and finish reaming that last bit of metal with the die-grinder.
Your bits will live much longer and your work will be safer.:cool:
Keep the drive-belts just loose enough that, when the bit grabs and wants to sling the work-piece across the shop, the belts slip instead.
My press has been set up as such and I haven't worn out a belt, nor spun a bearing, in over thirty years.
Also, my many years as a horse-shoer has trained my instincts to know just when a machine is fixing to "kick" and I un-consciously compensate by immediately tightening my hold on the work-piece.;)
For precision drilling, they make such a thing as a center-drill, which is a fat-shanked bit with a very skinny tip.
The fat shank prevents the bit from flexing, while the small tip centers within the punch mark and cuts a pilot hole.;)
I have one of those spring-loaded center punches that simply pushing down on it "snaps" the internal hammer and strikes the punch; it is about the handiest item I ever used for center punching.:)
   / Shop Tricks #109
My turn...
Use Valve lapping compound to get extra grip on a socket that is slipping.
Today I was removing the camshafts from a 150,000 Subaru engine, The 10mm bolts don't have a lot of torque, but over time they get tight. I had to move to a 6 point 3/8 drive socket with a long handle, and felt two of the bolts start to slip. I ran and got some valve lapping compound and coated the head of the bolt- it provided enough friction to remove and reuse both bolts.
If its starts to slip, try this trick.
Steve
   / Shop Tricks #110
My turn...
Steve
Good tip. Works with Philips head screws, too.
   / Shop Tricks #111
>> DRILL PRESS TIPs <<
Hey Bearkiller,
I'm not a machinist by a long shot and an old timer told me once that by tightening a 3 jaw chuck in all 3 holes it helps to center the bit and make it more accurate, especially on a lathe. That's why he always used a 4 jaw chuck.
Clem
   / Shop Tricks #112
>> FREE PERSONALIZED STICKERS <<
This tip won't work for everyone, but is really neat for those that are fortunate enough to benefit from it.
For the last several local/state elections, there have been two candidates that both have the same last name as I. (I have never voted for either)
During their campaigns, both of these guys, and often also their supporters, will come into our public business and leave a big stack of bumper-stickers, along with such things as match-books, ink-pens, key-tags, etc.
As soon as they are gone, I grab all the stickers.
In big bold letters is my last name.:D
I take the scissors to the stickers, neatly cutting out my last name, tossing the rest in the trash.
I stick these on gates, equipment, trailers, tools, anywhere that I want people to know "this is mine".;)
   / Shop Tricks #113
OTOH, people might remember the name and think YOU are a politician :D:D:D
   / Shop Tricks #116
Add "integrity" to that list and I'll vote for you as the next Maine state senator!
I dunno...he said he takes ALL of the stickers.....
Sounds more like the people we have had for some time.
   / Shop Tricks #117
This is more of an application (non mechanical) tip rather than a "shop" tip...and it's widely know among most wood workers...
When you're fastening or repairing thin or small pieces of wood with finish nails or brads...flatten or blunt the point of the nail to prevent splits...
The flattened point tends to punch a hole through the wood rather than parting (splitting) the fibers...
another wood working tip is to rub the threads of wood screws with bar soap or candle wax when penetrating hard woods...
one more...in a pinch a length of nylon string can be used to cut PVC pipe (even schedule 40)
OK one more (for trim carpentry) when fitting mitered boards like window or door casings etc...it can be difficult to hold a tape measure on the "short point" of a 45 or other angled cut...using a piece of wood or plywood ...hook your tape on a square end and make a mark (crowfoot, i.e., ^) at the desired length...then hold the "short point" of the mitered end of the molding on the square end of the board or plywood and transfer the measured mark onto the molding to make the second miter cut..
   / Shop Tricks #118
[/COLOR]
Or just add the ammount of margin you want.
Example: If you're trimming an interior door measure from the bottom of the jamb to the inside edge of the top jamb. Usually 81" just add 1/4" making 81 1-4" and that's your short point.
If it's a window and it measures 36x48" to the inside edge of the jambs you would add 1/2" because you need 1/4" on each end. This would be 36 1/2"x 48 1/2"
Clear as mud right?:)
   / Shop Tricks #119
Sorry /pine I figured out what you were trying to explain and you're right that method will work fine. You were talking about tranfering your measurments to the peice of trim.
I usually just lock my tape and "burn an inch" meaning I hold the 1" mark on the short point and add an inch to my measurment. Either way works fine- to each his own.
   / Shop Tricks #120
..."burn an inch" meaning I hold the 1" mark on the short point...[/url]
I agree this is an accurate way to measure (cutting an inch etc)...but sometimes holding a tape against certain types of moldings can be awkward.
[note]
something else that probably should be pointed out for non-profrssional wood workers is...when doing such work as trimming/casing where there are multiple miter joints...you should almost always measure "short points" of angle/miter cuts...The reason being...all milled stock may not be perfectly dimensioned...and on intricate joints even a fraction can make a big difference (especially on stained or finish work that does not get calked and painted)...by cutting "short points" should one piece of material me slightly different it will show up on the (outside) long points that can easily be trimmed back on the opposite piece which is not nearly as noticeable...FWIW
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
2022 Ram 2500 (A55973)
2021 CATERPILLAR 323 EXCAVATOR (A60429)
2021 CATERPILLAR...
2014 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2014 KOMATSU...
