B7335 light kit for the B2320
   / B7335 light kit for the B2320 #34
   / B7335 light kit for the B2320 #35
So the better and cheaper solution was to buy the 40 amp alternator, wire and switches and then modify the ROPS and fender? I'm sure you feel your idea was best for your purposes but I wouldn't want that setup.
No, the rear lights were the original set up...lights and drilled two holes with a switch...... Drilling two holes in the hinge portion of the rops is not wat I call modifing...although I'm sure the rops police would...
the alternator was for the forward lights and the cab heater, when my enclosure is finished...
   / B7335 light kit for the B2320 #36
I was quoted $86.00 shipped. ON deal? Or not. Thanks
   / B7335 light kit for the B2320 #37
That's about right. My local dealer had it on the shelf so I got to pay sales tax instead of shipping. :p
   / B7335 light kit for the B2320 #38
Have you guys done anything to keep that U bolt from rubbing the paint off the ROPS?
   / B7335 light kit for the B2320 #39
In past applications I used a thin piece of innertube. But eventually even that wears thru,, and gets the paint, so after that I stopped making the effort and touch up when needed..
   / B7335 light kit for the B2320 #40
Anyone purchase just the metal bracket and u-bolt from this kit? I really like the idea of using LED lamps so I don't draw on the alternator much.
In the past I've mounted a dual-beam Hella worklamp, which has been great (wired with a relay into the turn-signal circuit, so I could retain the factory switch - the turn signals have no real use for me).
This looks like a nice kit.
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
