2 B3200 ???
   / 2 B3200 ??? #1
kuboman
Canada
B3200, L5740,
I have the B3200 and would like to add extra lights and mount on the roll bar. Is there any extra wiring for this that is handy that I can use other than the 1 set Kubota puts on for the rear light they sell? Also the roll bar interferes with the 3pt top link when it is folded down. Has anyone come up with a solution for this other than taking it off.
   / 2 B3200 ??? #2
I don't know what your talking about here. My rollbar is down (hits top of garage when up) and has been for a couple of months and have not noticed any interference with 3ph top link.
   / 2 B3200 ???
With my roll bar down I cannot lift the 3pt all the way up when I have an implement attached. Otherwise the top link hits the rollbar and will bend.
   / 2 B3200 ??? #4
Same with my B3200. I put the roll bar one notch down. When I tried it 2 notches down I kept hitting my head on it. It is very much in the way when I am working in the woods.
Russ
   / 2 B3200 ???
Any ideas? I was thinking of cutting down the folding part of the rb so that when folded it is above the top link. I would cut off about 6" and then re weld the pivot bushings.
   / 2 B3200 ??? #6
Have you tried moving the top link down to the bottom attach hole? I have not but it might enough. I also had thought about extending the current roll bar fold down stops.
Russ
   / 2 B3200 ???
I did try moving the top link but it made no difference. I don't follow what you are saying about the fold down stops??
   / 2 B3200 ??? #8
My bar has 4 positions. Full up, quarter down, half down and full down. Only at full down does the bar interfere with the top link.
Russ
   / 2 B3200 ???
Gotchya. Problem with that is it is a head banger in the low stop and it bounces around in the next stop up. I think the cutoff saw and a welder are the answer.
   / 2 B3200 ??? #10
I think kubota made a tall roll bar so that you could sit under it while running the backhoe. If you are never going to use the factory hoe then shortening would solve the problem. I would like to shorten mine as well for the same reason.
Rob
KBH 25T Tender (A56438)
KBH 25T Tender...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Kubota LX2620 (A53317)
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
