Tire Chains for R4 Tires ??????????
   / Tire Chains for R4 Tires ?????????? #11
i bought a set of vbar makes a tremendous differance on snow or ice digs into the frozen ground. when i put tractor in barn on concret i drive on plywood so it dont reck the concrete,the 2inch link chains are the best they wount get lost in the weel lug but i was afraid they would hit fender so i went whith the vbar atached in center of weel. 100_4841.jpg
   / Tire Chains for R4 Tires ?????????? #12
mcd176,
I got the same chains for my 1715 and they work ok:rolleyes:
They do slip down in the treads,but still provide good bite.
I have a good supply of cross chains and have thought of adding more cross links like sal64 has done.
They ride rough on frozen gravel roads too!
I ran a set of chains on the front last year, but I might try going without this year and see what happens. I added some extra weight on the front in hopes that will help.
jas67,
I've had good luck using a 18" pry bar and a set on channel lock pliers
to adjust my chains. put them on,run them a while and then readjust.
   / Tire Chains for R4 Tires ?????????? #13
I'm looking to buy a set of (probably 2-link ladder) chains for my B7610's rear R4's (12-16.5). Tirechains.com has an installation tool for tensioning:
Snow Chains Install Tool
Is this tool necessary, or helpful?
What about spring tensioners?
Thanks,
Jay
My B7800's rear are R-4 (12.4-16) with 2-Link Ladder
I think that Snow Chain Install Tool would help on chain installation.
The biggest problem I have with installing chains is getting out the slack in order to make the connection. So having something to hold both ends of the chain assy. together, while working the ladders around the tire threads, and being able to adjust the tension as you progress around the tire, should make the job alot easier, and it looks like that tool would work.
I don't have liquid in my tires so on chain installation, both tires are off the ground
(jack stands) all the air is let out of both rear tires, install the chains, then air the tires back up(about 16 psi rather than 20 psi). Chains are nice and tight and they don't move
so I don't use spring tensioners.
Thanks you Jay for pointing out that Snow Chain Install Tool.
Bill
   / Tire Chains for R4 Tires ?????????? #14
I don't think the tool is a necessity myself.I will get them as tight as possible and put on some tensions,(bungy cords) then let then find their spot, And might have to shorten them up a link or two.I use a floor jack to jack up one side at a time works real slick. Good luck, and I had great results with that chain site...
   / Tire Chains for R4 Tires ?????????? #15
Thanks,
Jay
(great name)
The only tool I needed to install my chains was to cut off the extra links. Maybe on a big rig a chain tension tool is necessary, but I just spread out the chain on the garage floor, drove the tractor over them, wrapped them around the wheel, hooked the inside, and used the lever link on the outside.
I got it as tight as I could and had to remove a few links along the way, then ran in for an hour or so and re-tightened (and removed a couple more links.
Now it's sitting on there just fine without any springs, bungy cord, or tensioner needed. It may be different for bigger machines and for on road use, but for clearing my yard, this has worked out very well so far.
Good luck,
Jay
   / Tire Chains for R4 Tires ?????????? #16
Thanks,
Jay
Install tool not necessary, if you want to buy a useful tool get this one, then you can repair, mod or make your own chains.
Large Repair Pliar
By spring tensioners do you mean to take up the slack in the side chains. If so then IMO yes you do need them, you can use springs or bungees etc. Recently I've heard some say they don't use tensioners and prefer a little slop in their chains, not me, I make mine as tight as possible so you can't even hear them, and on some CUTs there is not much clearance for loose chains.
JB.
   / Tire Chains for R4 Tires ?????????? #17
i bought a set of vbar makes a tremendous differance on snow or ice digs into the frozen ground. when i put tractor in barn on concret i drive on plywood so it dont reck the concrete,the 2inch link chains are the best they wount get lost in the weel lug but i was afraid they would hit fender so i went whith the vbar atached in center of weel.View attachment 150355
These pics show a good example of chains that don't fit the tires (one clue is all the chain tighteners pulling the slack out).
Cutting the side chains to the right length, first to fit the inside of the tire, and then the outside (with a couple extra links for tightening/adjustment) would be the first order of business. Think of it as putting clothes on that are too large. They don't look good and don't perform the job well.
Fitted chains do not need tighteners (which get torn off from ice and sticks and rocks) that just cause frustrations. Those frustrations we don't need, and can save a lot of money.
My opinion. :)
   / Tire Chains for R4 Tires ?????????? #18
Well, if we are sharing family pictures. here are a couple of mine. :cool:
Looking at them I realized that I could tinker with them a bit more to get them straight(er) and tight(er) - and may do that if/when it warms up a bit.
The weekend forecast is calling for 1-2' of snow, starting on Friday. Sounds like fun! :D
Jay
   / Tire Chains for R4 Tires ?????????? #19
The weekend forecast is calling for 1-2' of snow, starting on Friday. Sounds like fun! :DJay
Enjoy the snow, sounds like you are still going get what WAS coming here too. They have downgraded our forecast from 30 cm to 5-10 cm.:)
   / Tire Chains for R4 Tires ?????????? #20
jaybrad
Enjoy the snow.
And yes, I think you need to straighten those cross chains out. :) :)
Nice to see a pic of chains that fit :)
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
Land Hero 24" Semi Automatic Tire Changer (A59814)
Land Hero 24" Semi...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
Rhino DB150 (A57148)
