2 inch receiver welded to lift arms
   / 2 inch receiver welded to lift arms #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I am considering welding a 2 inch receiver permanently to the large cross over pipe on the lift arms. This is pretty radical for me and I have not really thought about where exactly I would put it. It would primarly be used for a winch (hand powered). Just thinking out loud really. Any comments would be appreciated.
   / 2 inch receiver welded to lift arms #2
That would be handy, but here is a mod to a hand winch using a hyd motor. Just unplug the QA hyd and plug into the winch, and control things from the seat.
That's not bad. I will have to consider that. As usual, thanks for your input. I bought a receiver today and will play around with a configuration. I will take some pictures and hope for some comments and critiques.
   / 2 inch receiver welded to lift arms #4
Just curious are you going to use the winch for pulling logs out of the woods or pulling a stuck power trac out of the woods or snow?
Mostly stuck in the swamp stuff. Actually I was stuck in the snow last week and it would have worked for that. It does not snow a lot here, but when it does clearing the driveway is very important.
   / 2 inch receiver welded to lift arms #6
I would be worried about bending things especially if it is not a dead-on pull from the front.
Ken
   / 2 inch receiver welded to lift arms #7
Ken
Yeah, that would be my main concern as well. The FEL arms aren't meant to be torqued to the sides. I worry about that when dragging logs out of the woods with a ring in the 2" receiver and a chain on the ring. I try to keep the pulls straight and lift the end of the log off the ground so it won't suddenly grab in and put a shock load to the side.
   / 2 inch receiver welded to lift arms #8
I wish I had pictures, but what I did with my winch was I mounted the electic winch to a plate, then attached chains to the plate, Those chains hook onto the tractor's chain hooks (frame welded). I have yet to use it in the field but the system has worked in garage tests.
I agree. I cannot really put the 2 inch rec. on the center because the roll over mechanism will get in the way. I could put it low on the front plate that the bottom of the lift hydraulic cylinders are tied to. It would only be 8 inches off the ground. But it might work. Any comments or other suggestions?
   / 2 inch receiver welded to lift arms #10
I mounted a tow hook on the front plate between the FEL lift arms. I use that to chain it down on my trailer. I can get to it from either side, so I don't have to put my body under the raised FEL. That is something you need to consider if you want to mount a receiver under there. You don't want to raise the FEL and then go under it to operate a hand winch.
Have you considered putting a reciever on the inside of the top of your bucket?
Year: 2017 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 105,402 (A51694)
Year: 2017 Make...
Pop up camper (A51694)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
9ft x 7ft Shipping Container with Side Door (A51573)
9ft x 7ft Shipping...
2022 Heli Forklift (A51573)
2022 Heli Forklift...
