2 inch receiver welded to lift arms
   / 2 inch receiver welded to lift arms #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I am considering welding a 2 inch receiver permanently to the large cross over pipe on the lift arms. This is pretty radical for me and I have not really thought about where exactly I would put it. It would primarly be used for a winch (hand powered). Just thinking out loud really. Any comments would be appreciated.
   / 2 inch receiver welded to lift arms #2
That would be handy, but here is a mod to a hand winch using a hyd motor. Just unplug the QA hyd and plug into the winch, and control things from the seat.
That's not bad. I will have to consider that. As usual, thanks for your input. I bought a receiver today and will play around with a configuration. I will take some pictures and hope for some comments and critiques.
   / 2 inch receiver welded to lift arms #4
Just curious are you going to use the winch for pulling logs out of the woods or pulling a stuck power trac out of the woods or snow?
Mostly stuck in the swamp stuff. Actually I was stuck in the snow last week and it would have worked for that. It does not snow a lot here, but when it does clearing the driveway is very important.
   / 2 inch receiver welded to lift arms #6
I would be worried about bending things especially if it is not a dead-on pull from the front.
Ken
   / 2 inch receiver welded to lift arms #7
Ken
Yeah, that would be my main concern as well. The FEL arms aren't meant to be torqued to the sides. I worry about that when dragging logs out of the woods with a ring in the 2" receiver and a chain on the ring. I try to keep the pulls straight and lift the end of the log off the ground so it won't suddenly grab in and put a shock load to the side.
   / 2 inch receiver welded to lift arms #8
I wish I had pictures, but what I did with my winch was I mounted the electic winch to a plate, then attached chains to the plate, Those chains hook onto the tractor's chain hooks (frame welded). I have yet to use it in the field but the system has worked in garage tests.
I agree. I cannot really put the 2 inch rec. on the center because the roll over mechanism will get in the way. I could put it low on the front plate that the bottom of the lift hydraulic cylinders are tied to. It would only be 8 inches off the ground. But it might work. Any comments or other suggestions?
   / 2 inch receiver welded to lift arms #10
I mounted a tow hook on the front plate between the FEL lift arms. I use that to chain it down on my trailer. I can get to it from either side, so I don't have to put my body under the raised FEL. That is something you need to consider if you want to mount a receiver under there. You don't want to raise the FEL and then go under it to operate a hand winch.
Have you considered putting a reciever on the inside of the top of your bucket?
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
