8N doesn't start
   / 8N doesn't start #21
Everyone is getting a good lesson in the older Fords, which were and are a classic.
Good advice as I see it.
But would have done the distributor/wires/plugs/points/condenser/coil check first (or soon after the first experience with the ether not working :) ).
The 6 volts always seem to eat points and condensers.
Hope you have some good compression. All that cranking as mentioned makes me think it is cranking way too easy (or else the battery would'nt hold up long).
Only need three things. Fuel, spark, compression. But any one missing will mean "no start".
   / 8N doesn't start #22
It's been my experience that 6v is easy on points.. and 12v conversions is where you hit problems with people not making sure primary resistance is correct.
as far as the condensor is concearned.. considering dielectric insulation is probably near 100 to 200v.. 6v or 12v don't matter much.
soundguy
   / 8N doesn't start #23
Your suggestions on identifying the tractor are very good. As well as the specifics about the 2 distributors.
But I'm not sure why you are quoting me and saying how I'm making it harder. Why don't you just simplify it by telling him what he needs to know and skip the part about how much more you know than me.
Are you saying he shouldn't get the manual and arm himself with good information?
Knowing what tractor you have is just the start and quite the easiest thing to do... as you have proven. The real benefit of what I recommended is to have the instructions on how to actually do the tune up and trouble shoot the fuel delivery system.
I don't think I'm making his job harder, I'm making it easier by advising him to get one of the most important parts (the manual) for someone who doesn't know the machine and is working on this machine for the first time.
No one told him until I did that there are different distributors and you probably need to or at least should get into the distributor part of the ignition system to get it tuned and running. Obviously he is reluctant to get involved with the distributor because he lacks the knowledge and confidence. And one of his motivating factors is to have a successful father and son fix it project while they help the neighbor.
I stand by my first recommendation. Glad you were able to make it easier though.
You are making this too hard. Ford N series used 2 distribuitors stock.. a side mount.. and a front mount. front mount was the same for the 9n, 2n, and early 8n.
parts for the frontmount fit all the front mounts. parts for the side mount actually fit all the 4 cyl gassers up to 64.
Not even that hard... 3spd tranny = 9n/2n 4spd tranny = 8n
big rear axle nut = 8n.. smooth or rivited rear axle hub = 9n/2n
still.. the engine will have a sn on the side, above the starter, below the head that will tell you what the engine went to. All N engines swap.. so then you date the codes on the chassie to see if your engine matches your chassie.. general thoughts are if the casting codes and engine number all meet up within about 3 months or so.. you got a machine with no major swapped components.
soundguy
   / 8N doesn't start #24
saying there are multiple different designs and different ignition parts among the 3 units in the N series.. when all it really boils down to two of them.. EI.. any front mount uses common components. A 2n distribuitor will fit on a 9n, will fit on an early 8n.. etc. no different parts... And PS.. I did tell him how to ID it.
Not sure where you read that.. it wasn't in my message. I think everybody should have the manual that goes with their machine... and i state so often.
*Really* not sure where you read that one either. for sure wasn't in my message. You getting my reply mixed up with somebody else's???
soundguy
   / 8N doesn't start #25
soundguy
Fine. Good thing we are both trying to help him. I'm glad you're here to point out when I make it too hard. Again, the simple part is differentiating between the two distributor systems. I was just letting him know there are differences and the manual can help identify which he has, but quite beyond making that determination is using it to get the job done. The job by the way is not determining which distributor he has but getting the tractor back running.
   / 8N doesn't start #26
Here's an important tidbit. depending on which manual set he finds.. some o fthe 'previous' copies have a misprint in them as to pointsgap.
front mount gap at .015 and side mount gap at .025
plugs on either gap at .025
soundguy
   / 8N doesn't start #29
I have one in my tool box but haven't used it years. Not since the newer electronic ignition systems are being used.:D
   / 8N doesn't start
Gentlemen, please, no pissing contests on my account. One of the things that is most amazing about this forum is how friendly and willing everyone is to help and discuss things. You are all far more knowledgeable than me when it comes to the 8N and anything you tell me is one more thing than I knew before.
GP, you are very perceptive. Yes, I am reluctant to go too far for lack of experince and documentation and therefore confidence, but mostly because it was working last year and it wouldn't seem to be all that necessary.
I agree that the 'right' way to go about this would be to do the whole ignition system. I'd buy the manual and do it in a heartbeat if it were my tractor. I may still do it, but I know by painful experince how simple things snowball into messes. What appeared to be a simple blocked fuel system has grown to encompass a weak ignition system, plug wires that will spark a plug out of the cylinder, but not in the cylinder. And now, just for good measure, he pulled the rest of the plugs in anticipation of replacing them and found that they all have boogered up threads and the threads in the head are tight too. Some previous owner mustn't have cleaned out the depression the plugs sit in and dragged dirt down into the threads. One plug had the gasket rusted on about 2 threads below the shoulder, so it was never really seated. We are now taking the hood off so we can see how bad things are and wondering if we will have to chase the threads. Does anyone know how to do that without removing the head to keep the chips out of the cylinder?
With the hood out of the way, it may be easier to do the rest of the ignition system. I looked at it a little today. The cap appears to be square with 2 wires coming out of each side. It's on the front of the engine, very inconveniently located between engine and radiator and partially blocked from the side by the generator. It looks ok physically, but I know that doesn't mean much sometimes. I wasn't looking too long either, it's just too cold here to hang out long in an unheated shop.
By Soundguy's criteria, it's definately an 8N...Large nut on the rear wheel. We never did find any data plates. I'll look again above the starter, but I'm pretty sure that there was no tag there, although it did look like there was a place for one.
2014 HYUNDAI 53FT DRY VAN TRAILER (A59905)
2014 HYUNDAI 53FT...
2017 Caterpillar 249D Compact Track Loader Skid Steer (A59228)
2017 Caterpillar...
CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
CATERPILLAR M322D...
2018 RoGator 1100C (A56438)
2018 RoGator 1100C...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
