Yanmar (Chinese) Clone generators -- where to get a key?
   / Yanmar (Chinese) Clone generators -- where to get a key? #1
jas67
Central PA
Kubota B7610 + Kubota G1800-S
I have two nearly generators with Chinese-made clones of the Yanmar L70 engine (CF-178) (both purchased used). One is a Titan 5500, the other an ETQ (Eastern Tool and Equipment).
Here is a link to the ETQ one):
ETQ Diesel Generator DG4LE
The previous owner of the ETQ lost the key, but the key from the Titan fits, so I suspect these keys are like tractor keys, in that they don't bother keying the locks differently.
Because I only have one key between the two of them (no spare), I went to my trusty they-have-everything local hardware store to get copies, but they didn't have any appropriate blanks.
Of course, with most tractors, you just go to the dealer, and tell them what model tractor, and they'll sell you a key.
Any idea where to get keys for these generators?
Thank you,
Jay
   / Yanmar (Chinese) Clone generators -- where to get a key? #2
Post a picture of the key.
Try TSC or other farm stoor and look at the mower replacement keys or put a mower switch in that you can get parts for it should be an easy replacement.
tom
   / Yanmar (Chinese) Clone generators -- where to get a key? #3
+1 on the pic of the key. Some keys are very common. Both of my snowmobiles and the riding mower have the same key.
tom
I'll take a picture of the key tomorrow. The switch has 5 terminals, and 3 sets of contacts (start,run, and stop), so a mower switch won't do it (already thought of that and bought one, only to discover that it won't do it all).
Thanks tommu56 & tig.
J.
   / Yanmar (Chinese) Clone generators -- where to get a key? #7
I will check in the morning and see if it is the same.
   / Yanmar (Chinese) Clone generators -- where to get a key? #9
Do you have a wiring diagram?
After thinking about it a toggle switch and push button should work
and if it has glow plugs a second push button and relay for it.
check for a good lock shop they should have one to fit.
take the other lock with you to try it in at the shop blank should slide in before its cut.
check the other tractor dealers again take lock and key with you and see if key fits in.
tom
   / Yanmar (Chinese) Clone generators -- where to get a key? #10
Here is the pic of the key for my Chinese Yanmar clone generator.
That look just like the switch assy, same connector and all.
Here is a closeup of the key:
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Hydraulic rail grinder (A56438)
Hydraulic rail...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
