BX 25 Block Heater revisited....
/ BX 25 Block Heater revisited.... #1
Dpm708
Member
Berkley MA
BX25
Let me begin by saying I have looked at other threads/comments on BX block heaters. My BX 25 is kept under a tarp for now and have been able to start it after about 45 secs holding the glowplug light on. Have only used it 3-4 times to "rearrange " snow in my (gravel) drive way here in SE Mass. (Snowblower easier to manuver for initial cleaning.) I've been starting it about once a week to make sure it will. Slow cranking but it has started OK so far.
I wouldn't mind putting in a block heater as it seems there are those who feel it can't hurt in very cold weather.
My question would be.. Has anyone actually put a block heater in a BX 25 D902-E3 Engine this winter? ( Fall/Winter 2009) I have looked but have not taken off the engine cover to see well enough if this engine has a 25mm screwed in plug on the right side of the block that has been referred to in other posts. A screw in heater would be ideal as I would probably not try to do the freeze plug type. Maybe if I take the cover off I can see better, but for now I have no sheltered area where I can work on it. I would probably take it to a friends heated garage to do this if it seems reasonable.
The part # I have is 70000 73274 which seems to be a 25mm screw in block heater for around $40.
Would appreciate any thoughts from the experts out there...
Thanks
/ BX 25 Block Heater revisited.... #2
dpm, go to messicks.com and click on the kubota sign. then enter you're model number and click search. then click on engine. then click on crankcase. i think you're block heater would go where the part #170 is on the block. call messicks and make sure. it should be easy to install if that is where it goes. #170 on the block is part #06311-55020. hope this helps.
/ BX 25 Block Heater revisited.... #3
I installed a block heater in my BX 25 a few months ago. Though I too would have preferred that it be a screw in type..., the drive in 25mm diameter one is what fits in this engine. I had the threaded version and looked hard for a place to put it... No go. So, the drive in one goes on the left side of the block in front of the injection pump. It's not hard to do. The biggest nuisance is draining the radiator. You do have to remove the plastic engine cowling in order to gain decent access to the freeze plug, which comes out pretty easily. I have been using the heater for 60-90 minutes recently before starting and it starts VERY easily. I've also been using a battery tender. Cheap insurance and peace of mind with both devices.
/ BX 25 Block Heater revisited.... #4
This could be true and I would kick myself a bit if it is.
My heater is installed in one of the holes in which part 040 goes in the above referenced diagram
/ BX 25 Block Heater revisited.... #5
So is part #: 70000-73274 the correct block heater for the BX25, and is installed in the hole previously occupied by part #: 06311-55020 (170 on the diagram)?
I have a BX25, and I've been wanting a block heater for it, but I haven't been able to find the correct info for this. Can anyone confirm?
Well, here's what I've learned so far...I've looked at the engine diagrams at messicks for what is supposed to be BX23, BX24 and BX25 blocks. All appear to be the same. The screw in heater started with my looking at member "escavader's" post in 2008 ( http://www.tractorbynet.com/forums/...-bx-engine-905e-block-heater.html#post1543577 ) showing a 25mm port he installed a block heater. The quandry is that his engine is clearly a 905e even though messicks shows the same diagram for BX 23,24,25 engines ( my bx25 being a D902-E3) and there doesn't seem to be a screw in plug on the right side of the block diagram which might correspond to his location where he put his heater given the fact that his engine is not the same exact model as mine.
So my options seem to be:
Look into the plug area that member "bill in ny" suggested it might go and see if there is room and the right size?
Member "stradbash" apparently did install a drive-in one with good results but I am reluctant to try this. (In my case, Murphy's Law would be in full force)
Look into a lower radiator hose type?
As long as it's been starting at all, leave the darn thing alone and put a trickle charger on it?
Build a lean to/shed for it this spring and figure out if I still want to put in some kind of heater this summer?
Thanks to all.... Happy Winter !!!
/ BX 25 Block Heater revisited.... #7
I've considered a heater for my BX2350 but I have no problem starting it. So far it's fired right up while in the low teens and that's about as cold as I expect to have to deal with around here. I give the glow plugs about 15 to 20 seconds before cranking.
I expect that, even though it's starting, it would be better for the engine if it was preheated a little... help to get the oil flowing better sooner. Also, it's still very young and may not be so eager after a few years. For those reasons, I'll probably install a heater before next winter anyway.
/ BX 25 Block Heater revisited.... #8
I'd say get a diesel fired torpedo heater and set it up about 30 min before using and let it warm it up. Not ideal you will loose lots of the heat but it should be OK. Dont put it too close or you could melt some plastics or blister the paint
/ BX 25 Block Heater revisited.... #9
Well, I havent had to use the BX24 tractor when it was below -10 yet. I been able to start the tractor when it was below -5 before in middle of the night. It does start rough and then smooths out after it warms up. I had the tractor for over 3 years and haven't needed to warm engine yet, but since I am planning on keeping it for a long time, I probably will add the heater. I am watching this thread with interest.
I do beleive that adding a heater to it will make it start much quicker and many TBN'ers say. Of all the info I have seen for the recent BX's heater plugs, it all seems to be a drive in type.
/ BX 25 Block Heater revisited.... #10
I cannot say that the above will not work in a BX-25. I can say that part #: 70000-00771 will. I used mine again today. There are two freeze plugs on the left side of the block in front of the injection pump. The instructions say to put it in the forward one, which I did. I used high strength loctite and have had no leaks. I cleaned the hole and the heater well, made sure the hole stayed dry of creeping coolant, cleaned both parts with acetone, put the loctite on the heater and carefully drove it in. The directions for the heater say to use a 1" socket over the end while driving. I made a simple tool instead to help insure alignment so that I would not have it cocked in the hole when starting. I used a 1 lb. "deadblow" hammer and was careful about not hitting the heater any harder than I needed to. As far as I know..., I did not crack the block.:D
/ BX 25 Block Heater revisited.... #11
I received part #70000 73274 in the mail today.
The BX 25 is NOT listed in the installation instructions that came with the part. There are probably close to 75 models listed, including the BX 22, BX 23 and BX 2200, but not the BX 25.
I hope this helps. I'm planning to install my heater into my B 2100, tomorrow.
K
/ BX 25 Block Heater revisited.... #12
What oil are you using? I have never had any problem with the BX 1500 at even minus temps, but gained notable liveliness at startup using 5w-40 and SUDT.
larry
/ BX 25 Block Heater revisited.... #13
larry
BINGO!!
I live in MA also and I do NOT need a heater with a correct oil. Heck above -20F use a good group 4/5 and skip the heater. I do nto have time for cords etc.. PLus it is a time / $$$ saver.
/ BX 25 Block Heater revisited.... #14
Dear sw03,
As you might say..., I'd like to see the raw data on whether or or not it is a time and money saver. I will suggest that it is not as simple as you'd like us believe.
We may not -need- a block heater to start our tractors, but enjoy the peace the of mind, reduced clatter, easy starting and it makes us feel good.
Please leave us simple minded folks to our delusions...
/ BX 25 Block Heater revisited.... #15
Dear sw03,
OK...
/ BX 25 Block Heater revisited.... #16
Dear sw03,
Easy. Money saver is the heater (not needed about $40), cord to the heater (nice 12 awg $50) and a timer ($7) (unless you run it all the time and adds up bigtime on Kw). If not, your time is worth????
So runnning a nice group 4/5 (oil and nothing else) is lower piece of mind that what here? Is that RAW enough?
/ BX 25 Block Heater revisited.... #17
Last time I was up a little further north in Erroll, NH a guy had a pan of lit charcoal briquets under his oil pan. That's the NH way! :eek:
/ BX 25 Block Heater revisited.... #19
I have one of these block haters for my BX 25. So how much power do they consume?
Hey, we all make typos!!! :D:D
Without doing the whole math thing, you know, kilowatt hours times your power companies rates, etc, let me just say compare it to a similar electric appliance.
If you only use it when it is needed, such as plugging it in for 3-4 hours before use, you won't even notice it on your bill. Run it constantly, for no good reason I can see, and you'd notice a considerable spike.
If they are calling for a load of snow, I plug mine in, but it only takes 4 hours to accomplish its job.
/ BX 25 Block Heater revisited.... #20
I cannot put my hands on the information at the moment..., but my memory tells me that it is 400 watts.
golf cart (A56859)
golf cart (A56859)
2022 LEEBOY 8520B ASPHALT PAVER (A60429)
2022 LEEBOY 8520B...
2015 KOMATSU D61PX-23 CRAWLER DOZER (A60429)
2015 KOMATSU...
207282 (A52708)
207282 (A52708)
2020 CATERPILLAR D1 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
