Single acting cylinder to JD 4520
   / Single acting cylinder to JD 4520 #11
Using just one connection does work, as kennyd says it will.
I use one line to my single acting cyl. on my snow plow lift.
Use the FEL loader 'lift' outlet. Nothing attached to the other coupling.
The bucket curl outlets are plumbed to the two single acting cylinders that angle the snow plow.
   / Single acting cylinder to JD 4520 #13
Not harsh at all unless you hold the stick after the cyl. has retracted.
And you can just push it into float.
Thanks for the words of caution on operating. Don't know much about hydrolic plumbing, but I learned the physics of top-heavy equipment 50 years ago.
I guess I'm a little confused about how the joystick valve operates a SA cylinder with one line. If the joystick valve is opened to push fluid into the cylinder, the SA cylinder extends (to unload the mixer drum).
Then, if you let the joystick return to the neutral position, will the SA cylinder stay in the extended position? (Is there a check valve to hold the fluid in the SA cylinder?)
And do you move the joystick back past neutral to release the pressure and allow the SA cylinder to contract back to the closed position? (If so, how does the fluid get back into the reservoir? Will the other line still hooked up to the FEL then have pressure on the bucket curl cylinder?) EDIT: From re-reading the above posts, I gather both lines should be disconnected from the bucket curl cylinders so that the unused line can go into "relief" when the joystick is moved back past neutral.
Thanks again for your patience.
Greasemonkeyok
Hmmm, if I want to add a Top-N-Tilt to the BB (assuming BB = box blade), now would be the time to do it and let the top cylinder do double duty and be used for the mixer also. Less money and more versatility in the long run.
Is that logical?
   / Single acting cylinder to JD 4520 #16
That's what I was thinking would happen,,,,seams kinda harsh,,,,ideally would one run the 'other' to the tank ?
That is it's job, not harsh at all unless you hold it there for extended periods. Running the other port to the tank can be done, but not necessary at all.
   / Single acting cylinder to JD 4520 #17
Is that logical?
Yes.;)
   / Single acting cylinder to JD 4520 #18
Correct.
No check valve, but the port is "blocked" when the valve is neutral so no fluid can escape the cylinder, just like your loader stay's up after you raise it...
The other port should not be connected to anything. Fluid will try to go out that port when you lower the SA cylinder, but obviously will be blocked so the system will go into "relief", just like if you curl the bucket till it stops but keep holding the joystick.
This is not the ideal way (that would be adding a DA cylinder to the mixer) to do it, but it is functional and commonly accepted.
Clear as mud?:D
   / Single acting cylinder to JD 4520 #19
I guess I'm a little confused about how the joystick valve operates a SA cylinder with one line. If the joystick valve is opened to push fluid into the cylinder, the SA cylinder extends (to unload the mixer drum). (Correct)
Then, if you let the joystick return to the neutral position, will the SA cylinder stay in the extended position? (Is there a check valve to hold the fluid in the SA cylinder?) (Correct)
And do you move the joystick back past neutral to release the pressure and allow the SA cylinder to contract back to the closed position? (Correct)
Greasemonkeyok
You are correct...see inserts in the quote.
Give it a try.
You cannot hurt anything. Might hear some relief valve singing, but you know that is only temporary while holding the joy stick too long.
The JD kit for 3rd SCV (LVB 25513) is $264 list. About what I expected.
Dealer service department is vague about cost of installation, by the hour it "could be as much as $800". Later they backed off to say they would put a ceiling on the installation cost.
I realize there is a fair amount of work involved, so my question is: does the range of $400 to $800 sound reasonable? I know the Green paint is expensive, but are the Green uniforms that expensive also?
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2009 KENWORTH T6 SERIES SLEEPER (A52576)
2009 KENWORTH T6...
2024 JOHN DEERE 1025R LOT NUMBER 163 (A53084)
2024 JOHN DEERE...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
