Build A Pond?
   / Build A Pond?
This pair of trees turned out to be a major project. It rained resulting in more fun. Lots of shovel and axe work to get these two down. Finally dug deep enough to flood base and soften soil around remaing roots under base. At 65' high I didn't have enough chain to safely pull with tractor. Attached 1 ton cable winch to nearby tree and every few hours I'd crank it a few more notches. It finally fell sometine wed. night. Never got to see the big event-sound asleep. More rain today so top soil removal on hold.
   / Build A Pond? #72
I guess I need to find new ways to spend money as all the $ I am out on my half acre pond so far is 1000 bucks in fuel and a small dozer repair.
CTPRES:
We are in the excavating business, among other things, - - - - - hire someone who builds ponds and knows what he is doing!!!!!!! Don't try it on your own!!!!!!! Even without knowing much about your situation, there are many things to consider, design of primary spillway, secondary spillway, compaction, regulatory requirements, safety (moving that much material with that type of equipment takes time, time results in fatigue, fatigue may lead to mistakes), etc., etc.
Our farm is in Ohio, and it has to be easier to build a pond in Texas than in the hill country of Ohio. However, I find it amazing that people talk about building a pond for a few thousand dollars and in a few days. That is probably possible in the ideal location, but it isn't the case in instances. In fact, I often wonder if those people have ever built a pond. Or, did the build a mud hole?
For example, last year I built a pond on my farm with OUR employees and OUR equipment (750 JD dozer, 850 JD dozer, 160 JD excavator and a BOMAG for compaction). We had to construct a deep pond due to the lay of the land (ended up 17-18 feet deep) and it wasn't a dug pond like you would probably have. It was an impoundment with a dam. Quality fishing was important to us so we built structure and did a few extras. In the end, the pond was a little over an acre in size, we moved the 750 dozer and the excavator in on August 9. We took the 850 over two weeks later after the grub work and key were well under way. I pulled the equipment out the first week of November with a total cost of $65,000 - - - - and keep in mind that we owned the equipment and paid the employees thier regular hourly rate. In the end, we had approximately $ 30,000 in diesel fuel - - - the 850 alone burns 100 gallons of fuel a day.
I would think two or three times before I started to build any pond with a compact tractor. Just my two cents.
   / Build A Pond? #73
Huh!! who would have thought? That was a dandy idea. get the tree area wet and apply tension and crank it and leave it. :D One more bit of knowledge under my belt for future!:D
Congrats on getting the tree down easy and cheap! now the real work begins- cutting it up and getting it out of there in the MUD!! ;)
   / Build A Pond?
Rain and more rain so lots of time to think about moving 500 to 750 yards of dirt. Three combinations come to mind, keeping it cheap of couse!
Option one-FEL and dirt scoop. This option would be pretty fast but not a lot of dirt moved per trip. The good side of this one is dirt well placed and somewhat smoothed after dumping and no need to leave seat.
Option two-FEL and small trailer using FEL to dump it. More dirt per trip but more time spent messing with trailer.
Option three- FEL and dump trailer, something like King Kutter 1.5-DT-XB. Most dirt per trip but also most expensive.
Equipment cost per option. One $375, Two $25 (for parts) and Three $2,000
I really need to explain option two. I think I can also do this one without leaving seat. Have very old med. duty 4X5 trailer. Weld rear facing tow hook on top front of hitch and loop a chain under FEL. Using quick hitch to move trailer and fel/chain to grab and dump trailer.
Just thinking outloud, any comments?
   / Build A Pond? #75
I was looking at your options and had to wonder if the developing pond will stay dry enough to use any of them? We had a drought here that let me get into my pond and it was months before I could access some areas. Never went as far as I wanted. Your photo's looked like that is pretty saturated soil and going to be wet for awhile. I have never found that to be the ideal scenario for moving dirt.
MarkV
   / Build A Pond?
MarkV
MarkV You are right now it is wet, but it will be very dry by late summer. I am dividing work into two parts, digging and moving. 1- Digging hole and piling dirt near hole. 2- Moving dirt where needed later. Phase one digging, removing topsoil, is underway now. Due to moist soil this is very easy right now, all I do is slice six inch or so off edge by pushing FEL into hole at about 45 degrees. The options I'm working on right now are just to move the dirt after digging.
   / Build A Pond? #77
If you are just trying to get dirt out of the hole and pile it up on a bank for removal later when hole fills up again, I really cant see using anything else but the FEL and toothbar. using a trailer will eat your time and fuel when trying to get dirt out of the hole. The only way to make trailer worthwhile is have a buddy work with you with another tractor. you can load with your tractor and while he drives away to dump it somewhere you go back to scooping more dirt with both FEL and rear scoop and moving it out off the hole, waiting for your buddy to come back.
   / Build A Pond?
All the recent rain gave me a chance to test the water level. Now I have some idea as to how much dirt needs to be removed on the bank. End result will be a slope that can be safely mowed right to the waters edge with a zero turn. Top soil removal about 1/3 done. Current objective is to remove topsoil, slope shoreline and get something growing around the edges for erosion control
   / Build A Pond? #79
good start- is that a stream in the back of pic leading to some sort of a bridge ?
   / Build A Pond?
Good eye Radioman. Pond being built around wet weather stream with bridge on downstream end. Bridge is multi purpose. 1. Allows wet weather equipment crossing and 2. Determines water level. Water level will be adjusted by simply raising or lowering material on upstream side of culverts. Plus or minus a few inches the bottom of culverts establishes the wet weather water level and the low ends of dirt approach to culverts will allow for flood relief during very high water flows. This feature was tested sucessfully last week.
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
UNUSED PABREAK PC463 - 72" HYD PLATE COMPACTOR (A57193)
UNUSED PABREAK...
1999 Kubota L2500D Utility Loader Tractor (A55851)
1999 Kubota L2500D...
2014 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Mack CXU613...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
