R4 to R1 swap $$$
   / R4 to R1 swap $$$ #1
ElDorado
Adirondack Park
Kioti DK35
First off this is NOT a R4-R1 thread!!! That's a beat horse!! Now having said that I want to swap my R4s for R1s. My local dealer has a set of R1s. Both sets of tires are low hour tires. In addition I have chains that match the R4s.
My question to y'all is what should I expect for bartering? Other links here indicate about a $500 difference between the R4s vs the R1s, couple this with the chains for the R4s. Who's going to owe who? Should I expect to have to give additional cash?
From where I sit what I have cost more than what he has correct? Therefore worse case scenario would be a straight up trade. I am hoping that we can flop tires PLUS ????
Thoughts???
   / R4 to R1 swap $$$ #2
Did you tell us the tractor you have?
I sold my turfs off my BX on Craigs. Then I ordered a set of wheels/tires from Kubota Whole Goods. If I recall correctly, the R1s were a wee bit cheaper than the R4s I chose, but the price was not earth shaking different.
Yeah, straight up, for the dealers bother, sounds just about right. YMMV. A lot depends on what he has and what he needs for re-sale.
   / R4 to R1 swap $$$ #3
If both tires are similar in degree of wear, ideally it should be an even swap IMHO. The R4s cost a little more when ordered new, but the dealer deserves a little break for his business and he will probably be physically doing the tire swap. Most people buy R4s rather than R1s. You may actually be doing a favor for the dealer since R4s are more desireable for most buyers.
The chains is a whole different problem. Dealer may have little to no use for the chains. I would start by just bargaining with the tire swap. Maybe put the chains for sale on craigslist ect?
   / R4 to R1 swap $$$ #4
Yeah... yours should be worth more considering both sets have even amount of wear. But I bet the dealer is going to want something for it. And I agree it will probably be better for him to have a set of R4s laying around than a set of R1s... but you know people are in business to make money and he has something you want! Even if you did have a give a little for them it is still your best bet because buying new rims and tires aren't cheap and R1s are becoming more and more scarce on the compacts.
   / R4 to R1 swap $$$ #5
Doubt a dealer will give you cash back. Hope it works out in your favor tho...cash in the pocket. :)
   / R4 to R1 swap $$$ #6
A dealer will want profit on anything he sells.
Whenever he takes trade ins he needs profit there as well, its called wholesale/retail, so expect him to offer you a wholesale value on your trade ins.
My guess is that you'll be lucky if you get 50% of the used retail value of your tires/rims.
Don't forget he also has to warrantee your used tires when he resells them.
Plus your trades need to be a 'fast mover' or high demand set.
   / R4 to R1 swap $$$ #7
Why not buy them outright and sell the R4.s yourself on Craigslist or ebay if you believe there is that big a value difference.
   / R4 to R1 swap $$$ #8
Thoughts???
you are wanting to swap tires not the dealer, so he has the advantage. he may swap even but i doubt it.
   / R4 to R1 swap $$$ #9
Rims ... ?
larry
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
207270 (A52708)
207270 (A52708)
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2019 GALYEAN...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
