JD / Massey / Kubota Comparison w/prices
   / JD / Massey / Kubota Comparison w/prices
What model FEL was yours equipped with?
DK35SE HST only shows one loader, the KL351. I can't find anywhere on their site that its auto leveling.
   / JD / Massey / Kubota Comparison w/prices #32
I may be getting info overload, trying to spec out and evaluate some many models at once. Upon further review of my notes and dealer quotes, I see it is called "self leveling" and may only be on 45's and up.
"KL451 Kioti Loader Package ( self leveling, quick attaching bucket, 2800lbs lift) $4500"
the above is from a quote for a DK45SC
Maybe I am over analyzing data but not sure I like the width to weight ratio on that Kioti when it comes to using it on slopes. I have slopes to deal with.
Compared to the MF1635-
The DK45SE HST is 1100 lbs more heavy and more narrow
The DK35SE HST is 824 lbs more heavy and also more narrow
The width/weight ratio of the MF sounds better to me on slopes.
Added weight would be a plus for snow removal on the flat lot I would do but if that added weight is above the axles I would think it would be more tippy.
Anyone tell me if I am wrong in my thinking, not interested in rolling over :eek:
   / JD / Massey / Kubota Comparison w/prices #34
I am still looking at used for options in addition to simply putting a plow on my pick-up for snow removal and using a Garden tractor for the mowing.
A new V-Plow and new GT with locking differential is only $8,000 but not sure I want a plow on my pick-up, its an 05 Dodge Diesel and very capable.
Any input much appreciated!
I haven't read all the posts, just the first page, but...
I like having a tractor and would like a bigger one. But I have plowed snow with a pickup and plow and it's hard to beat, unless you get so much snow that you need a blower.
A heck of a lot cheaper to go with the V-plow and new GT.
That's what I am having a hard time with, we can get and easily get an 18" snow fall and I figure my 9000 lb pick-up with 8' poly V-plow would go right through it nicely and move it where ever I need using scoop mode.
For the tractor I feel a bucket would be inefficient and would go with a 6' pusher and let the tractor set on site during the winter months but an 18" snowfall might be too much for a pusher and I would end up doing bucket by bucket method.. sounds slow.
   / JD / Massey / Kubota Comparison w/prices #36
The KL 351 on the Kioti DK 35 does not have a self leveling loader.
   / JD / Massey / Kubota Comparison w/prices #37
I have been trying to clarify all this with the dealers- the Kioti website really has no definitive info.
Best I can tell, the self leveling is the KL 451, which I see on some DK45s, but not all. Some 45s I have looked at have the KL 401, which is not self leveling.
I guess it now begs the question- just how important is the self leveling feature?
   / JD / Massey / Kubota Comparison w/prices #38
Matt,
Height to weight ratio probably isn't the best comparison, since you don't know where the weight is distributed from tractor to tractor. Obviously,wider is better. But if the Kioti has it's extra weight below the center of gravity, it might actually be more stable even if it is narrower. Not saying it is; don't know for sure; and that is the point.
I own a Kioti and from what I can tell the weight is the the axles and transfer case. The engine sits low, very low too. Though, from what I've seen, most of the machines in the class all have similar engine mountings.
I've used CK25 on some pretty steep slopes. In fact, that is one of the reasons I liked it: heavy down low and wider than most I looked at. I most work mine on such slopes, and with loaded tires it's quite the beast, allowing me to work with heavy FEL loads without much concern for rollover or tipping.
From what I can tell, the MF seems like a really nice tractor. And if you can get into one with similar features for the same money, I'd probably go that way over the Kioti. But, I don't believe there is any appreciable difference in stability between them. Of course wider is wider, and certainly helps a great deal.
Also, remember that wider means that all your implements might have to be wider as well in order to cover your wheelbase. Wider implements might adversely affect your stability too, and make it harder to maneuver in tight spaces.
   / JD / Massey / Kubota Comparison w/prices #39
Read thru the posts so far. So, parameters are mow 1.5 acres and plow a 50x150' area?
The tractors noted are big for mowing 1.5 acres. You could easily do that with a 25-28hp tractor in a smaller chassis. Plowing or a 3pt PTO snow blower could surely run on a smaller less expensive tractor.
Actually if I smoothed the land some with a rental I could even use a Garden Tractor 2wd with locking differential would do for mowing.
Snow removal on the other hand is more demanding, here is a partial pic of that lot. I am at 4000' in Calaveras county just south of you.
[/IMG]
John Deere 5100M (A53317)
John Deere 5100M...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2010 CHEVY SILVERADO 3500 HD PICK UP TRUCK (A59575)
2010 CHEVY...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
