Just had a big hole dug in my front yard
   / Just had a big hole dug in my front yard
Oh, yeah. I forgot to mention that all of the banging and moving stuff around managed to dislodge enough debris from the water lines to plug up something in the washing machine. This wouldn't be so much of a problem except that my kids had this same stomach flu for the past few days and there's a lot of laundry to do.
The plumber is here today running new drian lines for the downstairs salon sink and bathroom. Come to find out I need a 2X6 wall rather than 2X4's along where the plumbing would go. I bet most of you already knew that. I'm just learning. I'll be going back to the lumber store soon to get what I need in 2X6's.
I'm not complaining. I'm just sharing for the amusement and enlightenment of the group.
   / Just had a big hole dug in my front yard #62
Update:
I finally got my new meter-main installed. I've been waiting 7 years for that. They did a pretty good job except that they somehow completely missed re-connecting the well pump. We discovered this last night at 9:00 after we got home from visiting my Mom. So the electrician came back out and we had water again before 10:00. He was very appologetic.
My house looks like swiss cheese right now because the HVAC guys came and cut openings for another half dozen vents but haven't installed the duct work yet. I have electric heaters strategically placed throughout the house to keep warm. They're waiting for me to re-do the cut joists pictured in post #52 before they run the duct work. I'd be further ahead on it, but my Grandpa ended up in the hospital so I went to visit him; and then today I'm laid up with a bad stomach flu.
I was planning on taking afternoons off this week to catch up, but things are pretty busy at work. I've only been getting off a few hours early at best. I may even have to put on a happy face and go in for a bit today because rumor has it that a customer is on a plane somewhere coming to visit with me to nail down a new development project.
No problems. Minor setbacks. All will be well in the end.
The response by the electrician is impressive. Glad to hear it worked out so well.
Hope your grandfather is OK. Best wishes to him from us and I hope you're feeling better soon also.
In this economy, busy is good!
8:30 at night and I finally got done with work.
I'm proud of me. I kept my lunch down the whole time.
If anyone was wondering, adding a few joists is not as easy as it sounds. The only way I can figure to put them in is to put the joist in flat and then rotate it into position. This creates a problem because when the new joist is still at an angle it's taller than the space it has to fit into. I've put in three now, and every one was a fight.
I did learn it goes in easier if I put the top in place and pound the bottom to straighten it. This way there are only a few inches of friction on either side vs. the entire top length of the board if I try it the other way. Another trick I learned about midnight last night is that if I smear a bit of construction adhesive on the part of the board that has to slide accross the sill plate it acts like a lubricant. It makes it slightly easier to beat into position.
I plan to finish the joist project tonight so that the plumber and HVAC guy can come finish their part tomorrow. I think I'm going to try something new tonight. I'm going to cut a piece of angle to screw to the bottom of the new joist. The point here is to create a wear plate that I can hammer on without bludgeoning the board to splinters.
   / Just had a big hole dug in my front yard #66
As far as smashing the edge of each 2x6 new joist, are you using a hammer or a sledge? If you use a scrap piece at the edge of the joist and hit it it will take the wear and tear instead of your joists. If you don't have someone to hold the 2x6 joist in position, at the middle as you hit/force it into place, you could screw a scrap piece of 2x6 into the end where you need to pound it to give you an extra 'hand', then unscrew the scrap after. Or you could jack up ever so lightly on the area from underneath to allow the new joist to fit better during installation and then release pressure/lift once the joist is securely in place.
Also, I think I saw fiberglass insulation stuffed into the space above your existing sill plate and the cellar ceiling joists-yes? If so, I recommend strongly to remove all of that and take 2" blueboard insulation and cut it to press fit against your outer rim joist and then seal each joist box with spray foam from a can to seal out any air infiltration. Otherwise the dew point finds its way into the fiberglass and saturates your sill plate and then you have a rotted sill plate and rim joist- I live in VT so these things we learn from hard experience.:(
2" is the best to use, if you can fit it since it will stop the dew point from finding its way in or out of your cellar. Air movement it the enemy- hot moist air moving to cold outside conditions can be stopped and it makes all the difference in being warm or feeling chilled and damp in a cellar. I would also put 2" blueboard from floor to ceiling in the newly poured foundation walls area to help with the same issues. By code it needs to be covered by some sort of fireproof paint or sheetrock for fire protection/burn time.
Things look good otherwise!:D
And as to one piece tubs- they are good if you can get them in as you have done during construction; but for future reference and for others doing similar projects Sterling, a division of Kohler makes some two piece shower tub kits that are solid as heck and are made of vitrile(sp?) which is MUCH better than fiberglass, and makes for a really nice unit that can be removed later if necessary and re-used too. I have a couple of them in a couple of houses I have and they have been great for new and retrofit construction.
I agree with the outside breaker box being not the best solution- but that is obviously your decision based on budget and your particular situation. Glad to see you are tackling the wiring nightmare and the plumbing now instead of later or never. Keep up the good work and level of enthusiasm.:)
Here are pictures of the before and after of the joists. The first two pics are before shots, and the second two were taken tonight. It may not be perfect, but it's a whole lot better than it was. It will hold the house up. I have one more joist to do, but I have to wait for the plumber to remove all of the old line.
I still haven't done much with the wiring.
   / Just had a big hole dug in my front yard #68
Nice job sistering up the joists. I didn't think to mention before, but if you have a 5ton bottle jack, you can put it under the existing joist with a 4x4 to raise the joist slightly to help allow room for the new one to go in.
I ended up using a 2 ton floor jack with a 2X4. It helped a lot. The additional benefit to this whole exercise is that I have eliminated all of the squeaks in the floor of the kitchen that is directly above this area. Now I'm thinking about jacking up some more of the floor and running construction adhesive between the joist and the subfloor.
   / Just had a big hole dug in my front yard #70
Sounds like me with my tractor...I just keep finding one more thing to improve. LOL
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A55852)
2013 International...
UNUSED X-STAR 250 GALLON FUEL TANK (A57192)
UNUSED X-STAR 250...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2021 Club Car Carryall 500 Electric Utility Cart (A55851)
2021 Club Car...
2019 CATERPILLAR PC306B HYD PLANER (A52707)
2019 CATERPILLAR...
UNUSED PABREAK METAL BUCK SHOOTING TARGET (A57193)
UNUSED PABREAK...
