Road Compactor attachment
/ Road Compactor attachment #1
E/S
Gold Member
Reno, NV
Kubota M8540HDC12-1 4x4 w/ Cab
I do some road building and grading, I would really like to compact my work without having to own another dedicated piece of equipment ( too mine engines around here all ready ).
I have a fixed tail on my box scraper and that helps, but it is tough to get good compaction.
Any input would be greatly appreciated.
E/S
/ Road Compactor attachment #2
Best compactor I've found is the tires of the vehicle.
After loosening the gravel (assuming that is what you are talking about) and spreading the gravel, then driving on it right away and before any of the fines dry out - - is the best and cheapest compactor.
/ Road Compactor attachment #3
I did a google search for this some time ago.. and I did not find a thing..
I wonder if one exists?
/ Road Compactor attachment #4
Why not use a roller? Filled with water (or another liquid), seem like that would work well.
However, if your road has a crown, a roller probably won't work.
That is part of what I am trying to do, but covering every inch of 2 lane, 2 mile long eats too much fuel.
E/S
I did the same thing and found nothing.
i know they exist, my ex neighbor had one 15 years ago.
E/S
The one I saw was 3 rollers, filled with water and staggered to cover approximately 10'.
E/S
/ Road Compactor attachment #8
About 5 yrs ago I was looking for a roller and started watching Ebay. After 6 months, I bid on one that was only located 100 miles from my parents farm and got it for $100. Of course, it cost me $400 to transport it to my parents farm. I dismantled and removed the front roller and welded on a lunette pin hitch. The following year I cut off the back end of the roller and using an old cornpicker frame my father had, made a hitch for the larger rear roller. I then turned around and sold the remaining hulk (center portion and engine) for scrap for $100.
/ Road Compactor attachment #9
E/S
But it is cheap compared to anything else you will come up with, and does the job very well. A roller will not do it near as well.
/ Road Compactor attachment #11
I was given a home made roler. 20 in pipe welded ends with car front spindles welded on and pipe frame for the pull type hitch. I don't know how he did it but it is filed with cement. I had fun getting it the 3 miles home. It,s 8 ft wide I just hooked it to the back of my truck and went slow. It is too wide to do a good job on the road with the crown but it works it would be better if it were only 4 or 5 ft wide. hope this helps.
Thanks Wolfpack, the smaller version is the kind of implement I am looking for.
E/S
/ Road Compactor attachment #13
E/S,
I like the smaller one too, just need one to fill in the space between your rear tires with a small overlap. If the roller is too wide it is hard to maintain good contact.
Thanks for all the input.
I am currently looking for some large diameter pipe to make my own, any ideas?
/ Road Compactor attachment #15
How about an old propane tank? The rounded ends should reduce the marking in turns. Propane tanks are not to hard to find, best if you can find one with bungs on the ends to fasten to.
/ Road Compactor attachment #17
If you make a big roller, then consider building it with brakes (the person in the link did not do that, and wonder how he managed?).
I have a 700 pound roller, and when it wants to start pushing you downhill, you better stay ahead of it and not get out of line. The roller will keep going. I pull it with the lawn tractor.
(And it will NOT pack loose gravel like one thinks it should, as it just rides on top)
I am thinking about that, just a little spoookey about cutting / welding on it.
E/S
I am looking at about 2000# in 8' wide, I don't think that will cause me pushing problems and will compact the gravel ( I HOPE ).
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
1992 John Deere 210C 58HP Loader Utility Tractor with Box Blade (A61572)
1992 John Deere...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
