Cat 1 attachment on Cat 2 tractor
   / Cat 1 attachment on Cat 2 tractor #1
Bikewanderer
Gold Member
I accidentally bought a cat 1 box blade for my IH 826.
How can I get this thing to fit my tractor?
   / Cat 1 attachment on Cat 2 tractor #2
They have sleeves that compensate for the difference in diameters.
I can't get the arms on the tractor close enough to get on the pins. I need a few inches. I wondered about longer pins but didn't want to just bend them.
   / Cat 1 attachment on Cat 2 tractor #4
I would think the arms could be adjusted in ........ but I'm admittedly over my head. I'm sure others with the knowledge on your machine will stop by.
   / Cat 1 attachment on Cat 2 tractor #5
Do you run out of adjustment in the lower arms? I'm not familiar with the IH 826 3PH arrangement but every tractor I've owned has lower arms that will adjust from quite narrow to wide enough to hit the tires.
I've never seen longer lower pins that would reach several inches. The forces would quite high on the end of the pins - especially with a box blade.
If there is no other solution, then cutting, welding, and thus modifying the pin mount would seem to be the best bet. Then you could mount Cat 2 pins on the lower arms. Reaming out the top link attachment point would take care of that as well.
If complete desperation takes over you can buy a Cat 2 drawbar from TSC for around $50 and weld it on.
The tractor has a two point hitch with 3pt conversion, but they don't go too close because the gearbox is in the way.
   / Cat 1 attachment on Cat 2 tractor #8
Here is a photo of a Cat 2 drawbar welded to an old Ford 101 plow.
You could do something similar with a box scraper. Do you have a photo of the box scraper mount for additional suggestions?
   / Cat 1 attachment on Cat 2 tractor #9
If you bought implement new take it back and get a cat 2.
   / Cat 1 attachment on Cat 2 tractor #10
RPW has a good idea. Putting a lighter duty box blade on a larger tractor may turn it into a pretzel sooner than later. Try to exchange it for a larger one.
2015 CASE SV280 SKID STEER (A60429)
2015 CASE SV280...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
