bx2660 and post hole digger
   / bx2660 and post hole digger
Hey come drive that thing on out to missouri, Ive got plenty of holes that you can use that on!
   / bx2660 and post hole digger #22
I have a Taylor Way post hole digger 12" auger that was on a B3200. Hooked it up to nephews BX2360 and drilled a few holes. It was sitting about 4"s off the ground so we installed my cheap QH's to extend it further back which raised it several more inches off the ground so I can now testify to the fact that it will work. Here's pictures for proof that are only 30 minutes old or less. One picture with it on B3200. Going down hill or on flat land should be no problem. He was going up hill so it got closer. Steep uphill may require backing up. No problem with power of tractor. Only issue is dragging ground.
ok great the phd will work, now I hope the 5' bb that I have wont be toooo much counter weight with the fel...getting one step closer to getting this charm...
   / bx2660 and post hole digger #24
It'll work fine as long as you realize what you have. It will stop you, but just raise it up a little, and continue on your way. I was debating between the 4' and 5', and am happy I went with the 5'.:thumbsup:
   / bx2660 and post hole digger #25
John thomas- glad to see pictures of full sized PHD on the BX instead of hearsay. keep up the good work! :thumbsup:
   / bx2660 and post hole digger #26
Hmmmmm! Very interesting comment. I guess I'll have to get mine put back together so I can post a picture of my full sized unit with an 18" extension on it. At first, I was a little taken aback by this statement, but then again, I also am skeptical of things that cannot be proven. John Thomas said he wouldn't believe I had implements stacked 5 high unless I posted a picture. Wonder whether he believes me now?
   / bx2660 and post hole digger #27
I don't remember saying that, not denying, just don't remember.:) As far as proof (you know what I'm talking about:)) you do know that pictures can be altered.:) But, having seen your pictures as proof, I have faith that you didn't alter them:). I now believe and will testify, with the disclaimer that I'm testifying based on pictures and not actually seeing in person, that TomH can and has stcked implements 5 high. I will also add that he's one smart and industrious worker and that I'd love to sit down with him in his garage one day, after studying it in depth (his garage) and discuss his past, present and future and my past, present and future.:)
I told my nephew that he had to stop by the house so I could get pictures that there was an ongoing discussion about the PHD fitting on a BX. I didn't think mine would and I never jumped in the conversation until I saw it with my own eyes. If I had given an opinion about mine fitting/not fitting a BX before I saw it with my own eyes, I would have been wrong. I now can testify that a Taylor Way PHD will fit on a BX2360 or one specific BX2360. I'd tell it as witnessed fact. It is still to close to the ground when traveling so I'll recommend getting one for a BX.
   / bx2660 and post hole digger #30
To offer some positive feedback.
Those are some helpful videos, I just saw them all after searching this topic.
2019 John Deere S780 Combine (A53342)
2019 John Deere...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
HARDEE D-3-816 LOT NUMBER 155 (A53084)
HARDEE D-3-816 LOT...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
