At Home In The Woods
   / At Home In The Woods
Dead Tractor Battery
When I tried to start the tractor in order to pull the "visitors'" truck out of the mud on Saturday, the battery was dead. We had to jump start the tractor. After starting the tractor, the battery never charged even though the tractor ran over an hour.
attachment.php
This evening I put a battery charger on the battery to see if the battery will take a charge. I really hope it's just a bad battery and not a bad alternator.
attachment.php
Look where the alternator is. It appears that the muffler will have to be removed if we have to replace the alternator.
attachment.php
And check this out. The muffler is tack-welded to the frame! Yuk. If the alternator is bad, I'll have to take the tractor to the shop and get it replaced. Alternators should be easy to replace, even for amateurs like me.
Plumbing installation has started this week.
attachment.php
Here's where the washer and dryer will go.
attachment.php
Here's where the laundry sink will be.
Hall Bath Plumbing
attachment.php
attachment.php
Master Bath Plumbing
attachment.php
Master vanity
attachment.php
Master toilet
attachment.php
Shower
   / At Home In The Woods #1,025
And check this out. The muffler is tack-welded to the frame! Yuk. If the alternator is bad, I'll have to take the tractor to the shop and get it replaced. What a horrible design. Alternators should be easy to replace, even for amateurs like me.
If you have a volt meter, you can start the tractor and then remove one of the battery terminals and test across the terminals for voltage. This should tell you if the alternator is working or not.
Plumbing Drains Under the Main Floor
attachment.php
attachment.php
The stack on the left in the picture is the radon vent. The stack on the right drains the hall bathroom.
   / At Home In The Woods #1,027
attachment.php
I'm no expert by any means, but shouldn't there be a trap on that drain that comes through the floor for the bath/shower? Or is that the drain for the toilet (after thought)?
I just looked at the technical manual. The manual says to remove the side panel on the left side in order to access the alternator. That's good news.
attachment.php
If the charger is able to charge the battery, then I'm guessing the alternator is bad so I'll have to replace the alternator. If the battery charger won't charge the battery, then I'll replace the battery.
   / At Home In The Woods #1,029
attachment.php
Don't rule out something simple like a loose or broken wire - it happens and causes some inconvenience.
Jim
   / At Home In The Woods #1,030
The house sure looks allot better with pipes in the walls!!!!!!!!!
I really like the cleanouts your plumber is putting in. You can never have too many. I like to run them out the exterior wall if I can, or have access through a vent pipe. Having them in the wall like he's done is really a smart move.
One thing that I don't care for are the PVC toilet mounts. Over time, and it's not very long, they tend to bend and wear away. Just with normal use, the toilet will start to move, and then it's very difficult to get the bolts to hold the toilet in place. I use metal plates on top of the PVC to solve this problem when it gets that bad.
On new construction, I always use metal for the toilet mount. It's not too late to change it, and in the long term, not having to ever deal with a loose toilet is always kind of nice.
Congrats on your progress so far!!!
Eddie
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
REDDICK 300 GALLON FRONT MOUNTY POLY TANK (A52708)
REDDICK 300 GALLON...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
KMC POULTRY HOUSE KEEPER (A58374)
KMC POULTRY HOUSE...
JOHN DEERE 6500 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 6500...
