At Home In The Woods
   / At Home In The Woods
Sheetrock Questions
We have interviewed 3 drywall subs.
1. Nails and screws. One sub uses only screws to attach the drywall, no nails. The other 2 subs nail the drywall around the edges and screw the centers. Which is better? Is nailing around the edges and screwing the centers adequate?
2. Gluing. One of the subs glues the drywall to the framing in addition to nailing the edges and screwing the centers. Is glue necessary? What are the pros and cons about gluing the drywall to the framing?
Thanks,
Obed
Long answer is yes, because it prevents smelly sewer gas from coming out of the drain. All drains should have a trap.
Thanks CurlyDave. That makes sense.
attachment.php
Today the wife put boxes in the kitchen to simulate the kitchen layout to help her make sure the cabinets and layout will be something she will like.
The first box on the left is where a pantry will go. The box to the right of the pantry is where the refrigerator will go. The box to the right of the fridge will be a cabinet that contains an oven and a microwave. The stovetop will go where the cardboard is sitting on the floor to the right of the wife and baby. The felt on the floor is where the sink and bar will go.
   / At Home In The Woods #1,044
A number of answers to various questions you posed. Your tractor battery and cable ends for the battery all need work. The battery should be removed and load tested by someone who has a load tester and knows how to use it. That will tell you definitively if the battery is dead or near its end of life cycle. The cable ends need to be cleaned thoroughly and properly coated if not replaced with new ones - I can't tell from the pics which is necessary. At a minimum get the battery cleaning tools from an auto supply store. And make sure to coat them when all is done to prevent corrosion and loss of power, especially on wet days. Try to get an Interstate brand battery for the tractor if you need a new one. I used to sell them and have them in 3 vehicles, four in my boat, one in my Kioti and a few in lawn tractors, atv's etc.
I do not see any purple pipe sealer on any of your plumbing fittings. Almost everybody uses the purple solvent after using the pvc cleaner to show that each and every connection was sealed. And it may be a code requirement for final inspection too- can't say for sure on this one. One thing for sure it lets one know where sealant has been used- that's why it is purple!
Trap for everything- now, not later. I have a laundry floor drain that has a trap in it but because it is designed to prevent flooding if a hose or something else fails the plumber said to occasionally fill the trap with light oil (like cooking, not motor oil) to keep the trap from going dry by evaporation. The light oil allows the water to pass through it if there is a need to do so because of a leak.
I see copper lines touching truss bracing and no clamps to prevent rubbing/chattering, etc. Any plumbing that can move by expansion contraction MUST be secured while you can get to it- ie. now.
Ditto on Eddie's idea of metal toilet flanges for the bolts to the floor.
Regarding sheet rocking; I would ask for quotes to spec out the total number of sheets, (5/8 inch thick if you have any over garage type applications, on the garage ceiling: fire code) asking for mold resistant wallboard for bath and possibly kitchen areas, etc. Get each sub to quote the entire job with skip troweled ceilings in your choice of pattern - (if they can do that for you). Include all materials, mud, tape, etc. You can have them do a prime coat of Zinzer tinted to a color that will serve as a base for your final coats of paint. They should spray the walls and ceiling with the prime coat(s). Then roll them out with a roller. The Zinzer product is kick-**s. We did it throughout our project and if done right even the first coat ends up looking great. For instance in my barn that is all I'm putting on the walls and ceiling in the garage bay section. No finish coats needed.
Have them tell you in writing how many guys for the job and start and completion time- expected for the entire job.
You may be surprised- we were- the quotes can vary widely.
Go see their work if you see the need to. 1/3 down, 1/3, 1/2 way through, and final when completed to your satisfaction. Sheetrock is way important to entire project's overall completion, aesthetics and sense of a job well done. Choose carefully and not the lowest bid unless you have verified their work. The 'mudding' and sanding must meet your level of expectation, speck how many coatings of mud and how many times they will be sanding- discuss it up front with whomever you choose. As to gluing and nails vs. screws, screws do not back out if the house is wind blown a lot. Nails, even if ring shank will pop when jolted by wind. Glue can't hurt in strengthening the wall to stud interface. Screws are the proven method, but doing perimeter nailing, if preferred probably won't hurt if done right.
That's it for now- back to work:thumbsup:
Keep wife and baby far away from any sheet rock dust!!
   / At Home In The Woods #1,045
attachment.php
They can never start to early!
_________________
Large Machining
   / At Home In The Woods #1,046
I vastly prefer screws to nails for drywall.
Very, very seldom do you ever seen screws pop out, nails do it all the time. The edges are especially sensitive, and should get the best fasteners not the lesser ones.
I have never seen sheetrock glued to studs. One bad feature I can think of is that it would make repair of a section much more difficult than just screws. Repairs are reasonably common, especially with kids in the house.
   / At Home In The Woods #1,047
I quoted all of Coyote Machine's post because it's so good. Read it and read it again!!!!
I'm embarassed that I missed the purple primer on the pipes. I saw how pretty they looked and didn't even think that they are TOO PRETTY!!!!
PVC is a very simple product. You don't glue it together, and you don't prime it. Those are words that are used, but that's not what's happening. The primer and glue are chemicals that react with the PVC and each other. The primer is really the fist step in conditioning, softening and changing the characteristics of the pipe. The glue reacts to the primer and the PVC and melts the two pieces of PVC together. You have to use both for it to work properly. Clear Heavy Duty glue is the best and the strongest. The other colors are specific for certain applications, but not as strong as the clear glue.
Either your plumber is the neatest guy on the planet and taking an extreme amount of time to make sure there isn't any mess, or he's not doing it right.
The purple primer is messy. It gets everywhere and it stains everything.
If in doubt, contact your inspector and ask about the proper way to glue to gether PVC pipe. If he doesn't know, contact your water district or water department. Mine was willing to educate me on what works and what doesn't.
Drain lines are not under pressure and are less likely to leak, so that might be why he cut the corner on the purple primer. Of course, one leak in your ceiling a year after you move in is just not worth what you save by not buying the purple primer.
Eddie
   / At Home In The Woods #1,048
Make sure the plumber is not using type M (thin wall) copper. Use at least type L.
   / At Home In The Woods #1,049
Sheetrock Questions
Thanks,
Obed
From what I understand, perimiter nailing is done for speed in hanging the drywall. I would make sure that are using ring shank nails. A drywall/painting sub that we use, does a lot of warranty repairs for a new custom home builder. He said the smooth nails are his bread and butter.
Glue if done properly saves fasteners, and therefore saves labor on the finishing with the nails.
Do a search on Myron Ferguson for drywall tips/videos, or buy one of his books. I recently read an article on the paperless by him.
   / At Home In The Woods #1,050
Good drywall and pipe advice! We did no glue, all screwed on drywall. Our plumber, the worst sub on our house, taped the glue and "primer" cans together with duct tape to avoid the temptation of not using primer. Given his lack of attention to detail and quality, it's a good idea.
One little thing I did was put a cut off valve for the refrigerator in the basement where I had easy and quick access. Standard protocol is to put the silly small valve behind the fridge, but then you have to roll it out to get to it. If you have hard wood floors, the cost reduced small wheels on the fridge will leave a mark (we had to roll ours around on 1/8" luon (sp?) board used for tile).
Put hose bib connections on each deck so you can wash them off.
Silly AC wiring things we did: You can get AC outlets at the box stores that have a built-in night light (LED based). So we have outlets in halls that you don't need outlets by code, but they are there for these automatic night lights. The hall outlets are also great for vacuum cleaning, since you don't have to go into a room to find an outlet. Also put an outlet or two in the master bath for this function.
If you have a room that might be or become a home office, be sure to add two more circuits. One for a laser printer, laminator, or other high current device and one for the coffee maker.
You're kitchen layout with boxes is great! We did that too. Now think about what appliances are on the counters and see if you need to have a few extra circuits. We have one area where there is a coffee maker, toaster oven, microwave above in the cabinet, and an outlet for a waffle maker. This is all in 6' of counter space, and your electrician will never think to put 4 circuits in a tight space like this.
Enclosed are pictures that show that I know about going nuts with wiring, and have thought about security when you have cats.
In our previous house, I wired every window. It was very time consuming and nerve racking when drilling the holes for the plungers. The current house has Anderson windows, and it looked even harder to work them. So I tried a different approach. I have all my interior doors wired with magnetic sensors, the plunger type you can't see. You you don't need to do all, but here's the thinking. I'm more concerned with someone breaking in when I'm gone than the whole place going nuts if someone breaks in while I'm there. So think about your house layout and a bad guy looking around. Are some some doors he'd have to open, like closet doors or doors to rooms you'd normally have closed? If so, then wire them. I also have all outside doors wired and the automation system announces when they open.
A lot of this comes down to if the bad guy will break a window or door to get in, if he'll break into an occupied house, and if when he's in (when you're gone) he will not open any closed door. Think about if you're away for a few days, is there an interior door the bad guy would have to open that you could leave closed and would work with the cats.
I also have a driveway sensor so if the bad guys come down the driveway anytime, I hear about it. Eddie Walker has a post going on that one. The combination of the driveway sensor and wiring just doors works good for me. You two need to talk about just what security is, and if the TV image of the bad guy breaking into the house in the middle of the day and the alarm goes nuts is realistic for your rural situation, or if you'd be happy to just know when doors are opened and when someone comes down the driveway.
We ran 18 gauge pair to a lot of rooms for in ceiling speakers. There are also good in wall speakers. Automation and alarm systems talk, and if you have enough speakers in the house you are not relying on a poor quality speaker in the cheap alarm console/panel on the wall. Leave a coil of 3' of wire against a stud or run wires between studs so you can grab it and it won't be trapped by the drywall. Take measurements and pictures so you can go back later and find them. You can add the speakers anytime. Suggested rooms are garage, just inside garage, kitchen, room you watch TV in, master bedroom, master bath, basement, shop. We did every room, but that's the overkill talkin'.
If this sounds good, I'll post how I did the interior doors and in particular how to work with the trades so they are not inconvenienced.
Other random low voltage ideas, if any sound interesting post and I'll elaborate:
I always ran 3 CAT5 when I ran any. Ethernet, Phone, Future. Same pull, just one or two more boxes of wire.
Simple satellite receiver needs 1 coax, digital recording type need 2, if you want off air or surveillance monitors add add another coax. I put an antennae in the attic with amplifier on it's own 18 guage DC power line (not using the coax).
Where you have a TV, put 2.5" conduit up to a box where the TV will hang. You may also want to put in boxes for speakers.
We have his and hers DVRs. We ran the HDMI to the TV in the TV room, and then ran 3 matched length coaxes to the bedroom for the component input on that TV. Also ran a coax for off air/surveillance. A cat5 for audio, a cat5 for the IR repeater, and a cat5 for TVs that can do Ethernet. Result is you can watch your satellite or recorded shows from either the TV room or the master bedroom with just one DVR.
I ran a cat5 to the laundry near the washer, behind the fridge with ice maker and under the dishwasher so I can have a water leak detectors.
Ran a cat5 to the attic for a heat sensor so I can tell if the attic is on fire.
Run cat5 to where you want alarm system panels.
Run cat5 to outside doors for doorbell and put in box. That way you can switch to a door phone to talk to who's there.
Everywhere I ran a video and power for surveillance, I ran a cat5 because in a few years the cost of the high def cameras will come down.
We put in a few places in the ceiling for smoke detectors. We have all of the "required by code" ones, and wanted some additional independent low voltage ones for the automation/alarm system. So we have smoke or heat detectors in the kitchen, shop, garage, office and above the dryer.
We put a few motion detectors in the ceilings for controlling lighting, more on the lighting in a second. On this and the smoke detectors, you can just put a round cover plate on for now while you're in the "fog of construction".
In a central part of the house, possibly in a closet, run two cat5's and put in an outlet. If you want, add another cat5 (same pull, just one more wire) for smoke or heat detector in case the WiFi catches fire. We did this and have the wireless router for the house in there. One cat5 is for ethernet for wired computers, the other for the DSL line. This just hides a nice piece of infrastructure. My work shop and tractor garage also have their own WiFi boxes.
Figure out where your satellite dish will go and put the 1.5" conduit out there now while you can dig things up or get in walls. If it's going on the side of the house, you can run the conduit there and prepare an area to bolt the dish too and run a #6 ground wire. Otherwise, the installer will do the "screw it to the roof" in which case the satellite dish isn't the only thing that gets screwed.:laughing:
In the kitchen, master bedroom, and by the deck doors we had the electrician put in one more gang worth of box. Then you put in a orange divider and you can add a push button or two for things down the road such as a panic or all lights on function. Avoids cluttering up the wall with lots of boxes.
One last topic: lighting. You can retrofit lighting control, but it cost about $80 to $125 per switch to do so, and $80 for the controller to AC connection. We wanted some lights that could be turned on by the security/automation system, such as some outdoor flood lights, some hall lights, the garage lights, and a sconce light in the main room. We also did each bedroom, but that's back to overkill. Now here's what we did for the control. We ran a 14-3 from the switch box that had the wire that went to the actual light bulb to a double gang box in a closet (so we had access to it but didn't have to look at it). In the switch box, we connected black to the AC power. Red went to the light bulb, and white went to the switch contact that would normally go to the light bulb. In the closet where the 14-3 came in the top of the double gang box, we wire nuted the red and white together (the white had a red tape on it so it wouldn't be confused with neutral). We put a wire nut cap on the black. This box also had a 18 gauge pair that came in the bottom of the box to run a single pole double throw relay (SPDT). I have a little circuit board for that which includes a metal shield to keep the high and low voltage separate. So the house wiring works all the time, and you can add a 12V relay that connects to your alarm/automation system later and control some lights. When I explained all this to the inspector, he was OK with it all.
All this together with an alarm controller gives you system functionality like:
When you open the garage doors into the house, lights come on in the garage and house.
When someone comes down the drive, the outside flood lights go on.
When you open the front door, outside and inside lights come on.
When you have a fire or panic, lights come on.
With motion detector, when you walk down the hall lights come on.
Use as many colors of cat5 as you can, you can order far more colors than the box store has. Label every wire as you pull it! When you plan all this, buy a few cans of different colored spray paint and hit where you'll put all these boxes. That way you can walk through the house and think about your design and you won't forget things when you doing the actual wiring.
I've left some advanced ideas out, but this post is too long as it is. Yell if you want more data or pictures.
Pete
SHOPBUILT S/A METAL TRAILER (A52708)
SHOPBUILT S/A...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
SKIL SAW 10" TABLE SAW (A58374)
SKIL SAW 10" TABLE...
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
