Cedar post fence
   / Cedar post fence #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
A couple of months ago, I asked (in the South forum) where I could get cedar posts cheap. Lee (Weldingisfun) offered to let me take all I could cut down and trim.:thumbsup: I will be using these cedars for a fence from my barn along my driveway and curving past the pond. Back on April 10th I was at his Goat Ranch and we worked hard. I cut the trees down and he drove his tractor and we both trimmed. Hard thing about it was we had to chain and pull the trees off a draw over a stream. We would have had a lot harder time loading my trailer if it was not for Lee's Mahindra 4500 and loader. We sat the loader bucket over a bunch of logs and wrapped a chain around them and the bucket to sling the logs to my trailer. Here are a few photos from unloading the trailer this afternoon and stacking the cedar. I counted 45 posts anywhere in size from 12 inches down to 4 inches and about a dozen braceing posts. I used the Big RED Beast to unload without breaking a sweat.
hugs, Brandi
   / Cedar post fence #2
A lot of posts there.
Two questions:
1. Do you debark those before using or do you use them as is?
2. Do you burry the big end or the small end?
   / Cedar post fence
Two questions:
CurlyDave,
I will debark them. I salvaged a cedar log from Hurricane Ike debris back in 2008 and the bark is falling off of it now. Why would I want to bury the small end?
hugs, Brandi
   / Cedar post fence #4
Brandi:
Somewhere I read about people installing them small end down for a reason which escapes my tired old brain at the moment.
I was hoping you might know.
   / Cedar post fence #5
I pile the posts to cure for a year or so and then the bark comes off with little effort. I have put little and big ends in the ground -- not sure it really makes any difference -- just depends on what fits in the post hole:eek:
   / Cedar post fence
I got 2 or 3 of my Dad's draw knives. They peel bark most easily.
hugs, Brandi
   / Cedar post fence #7
The guys around here who work with cedar logs commercially use a 3000 psi pressure washer to debark. If you have access to one, you might give it a try. Don't have one myself so I can't testify to their effectiveness.
Glad you got it all home OK.:)
   / Cedar post fence
Thanks Lee! It sure was easier unloading then loading. Only problem I had was getting all the logs with the big ends in the same direction. All my trees slowed that process. I rent a pressure washer every few years to clean off my wood deck and anything else that needs it. I was going to rent one this summer, but sooner now.
hugs, Brandi
   / Cedar post fence #9
Years ago I hauled Atlantic White Cedar posts out of Canada into New York state for farm and vinyard use. The mill in Canada would put a point on the butt end (kind of like a big pencile sharpener, lol) and leave the bark on. There were two sizes, one about two or three inches or so and the other five or six or so.
I would think the heavier butt end down would be best for a good anchor. That is the only way I ever saw it down, pounded or drilled.
   / Cedar post fence #10
I've used both a draw knife and press washer to debark my cedars....can't say which I prefer ...bit of a toss up. The press washer is a little easier but sure makes a heck of a mess....a lot more than the draw knife even.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
2006 Acura RL Sedan (A55853)
2006 Acura RL...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
