3320 rolled and damaged...new purchase
   / 3320 rolled and damaged...new purchase #11
That rockshaft housing is around $700 new....
Looks like a fun project, HANSON!
I think you will find the axle housing is a similar amount. Also, I can't see
what kind of hood damage you have, but that green plastic can be more
than those castings.
3x20s are still very new....it will not be easy finding any salvage units.
i lucked out and found all the three point parts.....a mile from home even.....hope to get this guy runnin soon the three point rockshaft housing is the big wait now....i can't wait to get this tractor functioning!!
   / 3320 rolled and damaged...new purchase #13
I would also like to know what a tractor in this condition went for at
auction. I like to buy them that way. Maybe I should consider going to
auctions again......
update...
Just got rockshaft housing replaced and put back together. everything seems to work good. No fenders or seat back on yet.
I noticed it was throwing a couple codes on the display panel
65 and 67
My service manual doesn't list either of these, anyone have any ideas??
   / 3320 rolled and damaged...new purchase #15
Codes 65 and 67? I think 65 is "sell tractor to Gizmo2":D
   / 3320 rolled and damaged...new purchase #16
65 and 67
So, I guess you have an eHydro tranny then. Error codes not in the
service manual? That's a surprise....I figured the factory manuals would
cover that. I hope that JD can help.
I guess we are not going to hear about the economics of this rebuild....
   / 3320 rolled and damaged...new purchase #17
update...
65 and 67
From the Technical Manual
Err 65
Right Amber Light OFF
Output from the Display is open
No right hazard signal on the ROPS
Check the right hazard light bulb, Check the 135 Grn wire for short to battery voltage or open circuit.
Err 67
Left Amber Light OFF
No Left hazard signal on the ROPS
Check the Left hazard light bulb, Check the 145 Grn wire for short to battery voltage or open circuit.
   / 3320 rolled and damaged...new purchase #18
When it is completely done the price will be 80 to 90 percent of current market value. I have never seen any real deals. There is always someone raising their hand at unbelieveable prices for these " projects ". Now for eternity there will be bearing failure and seal leaks raising to the surface. Too many aluminum and cast parts on these machines that will cause problems. I will pass and buy new.
When it is completely done the price will be 80 to 90 percent of current market value. .
how would you have any idea what i have into this???? Do you have a source for parts at cost??? I DO!!!!! Do you have a source for miscellaneous used parts??? I DO!!!
That is all besides the fact you have no idea what i paid for it to begin with.....
So I have a leak or bearing to fix down the road, at least i will have half of market value into mine and when you paid full price for one who got the better deal?????
Who wouldn't wanna have 10k into a 2008 3320 with 174 hrs??? i bet i get alot more than that when i trade it in!!!!!!!!
Thanks mattz for the codes, makes sense i have the rops off the machine now..... my tech manual on cd skipped right over those two code numbers....
   / 3320 rolled and damaged...new purchase #20
To the fox who can not reach the highest grapes they are surely the most sour.
Good luck with the restore Hanson. It's something I'd do myself!
2023 Yamaha VXC Wave Runner Jet Ski (A55758)
2023 Yamaha VXC...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2012 Cadilac SRX SUV (A55758)
2012 Cadilac SRX...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
