Add a ZD to a BX2350 setup?
   / Add a ZD to a BX2350 setup? #21
For reference, here are some pics of my Deere Z850 with the dump bagger.
   / Add a ZD to a BX2350 setup? #22
Thanks everyone for the replies,
I am going to go with the ZD, after some research I think in a couple of years I am going to switch the tractor to a B or L series for more power.
Im still scratching my head on the dethatcher/rock removal, I would love to get rid of the front rotary broom, I do more damage with it than good to the grass. I tried a landscape rake to pull the gravel out of the grass but it kind of fluffs it up but does not drag it out.
Using a flail mower with added overseeding knives allows you to dethatch with the overseeding knives.
And now as no one makes a pick up flail mower with a tank in the united states anymore and a "cylone rake" or ground driven sweeper may be an option but its one more piece of equipment.
I would keep the broom and use it for the rock as the grass will come back quickly from being whipped a bit. grass is very resilient-I would let the grass grow a bit before you try to use the broom to get rid of it- but with a flail mower its not something you need to fret about.
saying that the flail mower will shred everything up to so small a cutting it will degrade quickly with 2 slow passes and you have no dead grass from old grass covering it as it is composting quickly into the grass bed.
even buying the biggest commercial cylone rake and a flail mower will allow you to be out less money than a zero turn mower.
Hi All!
Thanks for the replies!
I ended up ordering the ZD and I got rid of the front sweeper/blade.
I timed the mow yesterday and it took 1 hour and 15 min, previously it was something around 2.25-2.30 hours.
My wife really likes to drive the ZD around, I think she might cut the grass sometimes.
Thanks Again!
   / Add a ZD to a BX2350 setup? #24
Hi All!
Thanks Again!
Super, they are great.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
DEUTZ MARATHON...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
