Current Skid Steer and Mulching heads
   / Current Skid Steer and Mulching heads #21
Takeuchi is just garbage.
That's funny.
You stick with your 8 inches of clearance, bolt on undercarraige, plastic hydraulic tank, low horse power landscaping tool, bobcat and I'll stick to a real machine.
Takeuchi has planetary final drives, designed to be a track loader not a skid steer with the wheels taken off and a track bolted on. The Takeuchi isn't even in the same class as a Boobcat. whatever your buddy did to tweaked the arms would have snapped your bobcat arm right off...Pa - leeeeeeees.
Check the size of your front idelers...the Takie crawls over rock/logs that would stop other CTLs. I can't get it stuck. The thing is a beast.
If your buying a CTL, there's only one choice.
   / Current Skid Steer and Mulching heads #22
Look at a Rayco C100 I have 4 of them on lease here in Texas. For there size (Cat,Bobcat,ASV,Takeuchi) will not out perform them.
   / Current Skid Steer and Mulching heads #23
I got a chance to check out a Lamtrac 6125 the other day. Wow!! These machines are very quality built. Grease fittings on all hinges, Swing out coolers, Awesome air tight cab, 4 cyl cummins engine, very heavy duty undercarriage. I didn't see anything that I didn't like. They are not priced out of sight like others out there.
   / Current Skid Steer and Mulching heads #24
A skid steer will never cut with a dedicated unit.
I always thought the Lamtrac machines were expensive???
New Takeuchi TL250 with cab heat & air, high flow Hyd, High ambient cooling package, reversible fan, 80" dirt bucket for $73K...good price??
Are there any major differences between the Fecon mulchers mfg in 2008, and current ones?
   / Current Skid Steer and Mulching heads #26
That's a real good price.
The newer Fecon heads have the HDT rotor which off sets the teeth. The older models teeth are all in a row.
Any idea when they went to the offset teeth? I have a price for a 2008 Fecon mulcher for $18K
Also, if you had to choose...Fecon or the Bradco 165-5?
   / Current Skid Steer and Mulching heads #28
For me, Fecon.
   / Current Skid Steer and Mulching heads #29
What area of the country are you in???
I'm in West Georgia
2005 DRAGON PRODUCTS 130BBL VACUUM TRAILER W/CHALLENGER VACUUM PUMP (A53843)
2005 DRAGON...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
2012 RAM 2500 (A53843)
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2012 Chevrolet Cruze Sedan (A53424)
2012 Chevrolet...
2011 JOHN DEERE 323D SKID STEER (A53843)
2011 JOHN DEERE...
