Current Skid Steer and Mulching heads
   / Current Skid Steer and Mulching heads #21
Takeuchi is just garbage.
That's funny.
You stick with your 8 inches of clearance, bolt on undercarraige, plastic hydraulic tank, low horse power landscaping tool, bobcat and I'll stick to a real machine.
Takeuchi has planetary final drives, designed to be a track loader not a skid steer with the wheels taken off and a track bolted on. The Takeuchi isn't even in the same class as a Boobcat. whatever your buddy did to tweaked the arms would have snapped your bobcat arm right off...Pa - leeeeeeees.
Check the size of your front idelers...the Takie crawls over rock/logs that would stop other CTLs. I can't get it stuck. The thing is a beast.
If your buying a CTL, there's only one choice.
   / Current Skid Steer and Mulching heads #22
Look at a Rayco C100 I have 4 of them on lease here in Texas. For there size (Cat,Bobcat,ASV,Takeuchi) will not out perform them.
   / Current Skid Steer and Mulching heads #23
I got a chance to check out a Lamtrac 6125 the other day. Wow!! These machines are very quality built. Grease fittings on all hinges, Swing out coolers, Awesome air tight cab, 4 cyl cummins engine, very heavy duty undercarriage. I didn't see anything that I didn't like. They are not priced out of sight like others out there.
   / Current Skid Steer and Mulching heads #24
A skid steer will never cut with a dedicated unit.
I always thought the Lamtrac machines were expensive???
New Takeuchi TL250 with cab heat & air, high flow Hyd, High ambient cooling package, reversible fan, 80" dirt bucket for $73K...good price??
Are there any major differences between the Fecon mulchers mfg in 2008, and current ones?
   / Current Skid Steer and Mulching heads #26
That's a real good price.
The newer Fecon heads have the HDT rotor which off sets the teeth. The older models teeth are all in a row.
Any idea when they went to the offset teeth? I have a price for a 2008 Fecon mulcher for $18K
Also, if you had to choose...Fecon or the Bradco 165-5?
   / Current Skid Steer and Mulching heads #28
For me, Fecon.
   / Current Skid Steer and Mulching heads #29
What area of the country are you in???
I'm in West Georgia
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
1997 CMC S102 END DUMP TRAILER (A53843)
1997 CMC S102 END...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
