Is my loader is piece of crap?
   / Is my loader is piece of crap?
Come on folks... the guy asked an honest question!
No need to turn on 'em like you're behind on your rabies vaccinations! :D
FWIW - the bucket pins on my old JD 80 FEL were gettin' pretty sloppy. I was planning to take it to a local machinist and have oversized bushings installed.
Cheaper than a new loader... likely about the same total cost as a good used bucket - IMO.
'Course the new 300CX has replaceable bushings - he could always go that route - and get more lift capacity in the bargain! :thumbsup:
AKfish
Hey! Thanks buddy. I appreciate it. For what it's worth, I wasn't excited, just curious was all. The manual calls for greaing everything in the loader every 10 hours, I stepped it up to every 5 hours. I have 2 John Deeres and am happy with both of them, and if I did sell the 990, I'd likely stick with John Deere, but I'm keeping it so no worries here! Thanks a bunch guys!
What about the lube? How often are you lubing the joints and are you using an EP, extreme pressure lube like molly grease? My FEL calls for twice a day, how ever I found that after two days hard use the pins are well coated with grease and no signs of wear.
The manual calls for every 10 hours, but I go every 5 hours, on the belief that lube is cheap, loaders are not!
AKfish
I re-read my post, and don't see where I turned on him, behind on my rabies shots or not. Where do you read that into my post?
It was hard to decipher if the OP had a question "Is my loader a piece of crap?" or a statement "my loader is piece of crap". Either way, my comment was that mine was not a piece of crap.
beenthere
It's all good! I was just stunned when I saw that there wern't any bushings in there is all. I know the 990 with the 430 loader is bottom of the JD line, but couldn't afford to pay another $15,000 for the upgrade and I didn't want payments is all. Here in a few months, I might upgrade though, to something with an easier shift!
   / Is my loader is piece of crap? #25
Can someone post pictures of FELs with and without replacable bushings? ... if I'm saying that right. I'm trying to understand here.
Ken
Ken
I cannot get pictures up. Computer is fouled up. We get a new puter Tues. I'll put up some pictures of a Bushless pivot point at least then.
   / Is my loader is piece of crap? #27
I noticed that all the pivot points are not insert bushed. I am aware that the pins are likely softer in material than the initial bushings themselves, but was surprised to see that the bushings were not replaceable. Is this typical?
None of my loaders had replaceable inner bushings. I am more concerned
about JD's thin 1/4" metal used on their QA brackets. On my 420, they
have gotten so sloppy, a repair is necessary.
Have you considered using new 1" pins, instead of the smaller JD ones? I
assume you are having trouble with the main boom pivot? If one of the
cylinder pivots, an unmodified 1" pin will probably be too tight in the
cross tube.
cross tube.
No, the tractor has just over 200 hours on it, but I couldn't get grease into one of the pivots and took it apart. I was fairly stunned, and was just wondering if it were normal. My mast's do move around a great deal and make noises, and I was trying to figure a way of making them more rigid, like selling the unit and getting something stouter!:D
   / Is my loader is piece of crap? #29
200 hours! Now I'm stunned.
You mean your main boom is loose, correct?
I suspect that the pivot in question never properly took grease, so it has
200 hours of dry operation. :-(
   / Is my loader is piece of crap? #30
Unless the loader mounts are loose, you're probably seeing normal movement in the loader. Next time you drop your loader off, retorque the mounts and see if that helps.
However, this is a quick attach loader so it's not going to be as stout as a permanently attached loader. You've got to expect some movement.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Deere 310L (A53317)
Deere 310L (A53317)
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2017 Versatille 260 (A60462)
2017 Versatille...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
