20 20
Elite Member
Hey while we're at it what about them motorcycles towing trailers?????? check out this guy towing a car
http://www.youtube.com/watch?v=HCalA006AZM
The Honda Element has an optional Class III hitch available (which I believe we are looking at the shiny pin in the picture, pinheads). The tires are obviously well sized for that load so its never going to jackknife. All manufactirere load ratings are stated with the vehicle fully fued, loaded with passengers in all seats and with luggage space ballasted. If the Honda is empty, then there's legally no issue with this rig.
1500 pound snowmobile transporter. Honda Element.
Is it just me?
"Nervous" ? No.
"Disturbing" that anyone would find it necessary to appoint themselves as deputy dot inspectors and go around snapping pics like this to post on a public forum - with plates clearly showing ? Yes.
Completely wrong. As Chris pointed out, they are usually with a splash of gas and a 100lb driver and they are probably naked.
Also, I am sure you could put a Class V hitch on that Honda too, that doesn't mean it's safe.
"never going to jackknife" because the tires are "well sized"? You have to be kidding, right? An empty trailer jackknifes easier than a loaded one because it skids easier. Sliding wheel wants to lead. Has little to nothing to do with how well the tires are sized.
As a matter of fact, I DO know what I'm talking about. I worked in the vehicle dynamics section of a major auto maufacturer doing design, testing, certification, "forseeable misuse" and other aspects of trailer towing on our vehicles. We test competitors, too, and the Honda Odessy and it's companions (Element and Scion) do an admirable job of structurally holding a hitch, trans temps, brake and cooling capacity. You're an armchair quarterback who never ran a fully loaded 3/4 ton truck with a 32' Airstream down Apache Trail at 50 mph (dirt section).
All vehicles must be certified at their stated full load capacities and a withness test performed and signed off on. Stopping is the greatest problem when trailer brakes are under capacity.
Those trailer tires are pretty good for cornering and can outdo most 15" and 16" tires, especially since they are on such wide wheels. The Jacknife will comeabout because of the tow vehicle yawrate, not the trailer.
I don't recall your job or how many reports you have done anything to ever coming up. But, I can tell you that based on what you are saying here, they aren't worth the paper they are written on.Yeah, I've spun a few on purpose. Don't tell me what my job was. I've signed more reports on this than you have or ever will.
What, exactly are you smoking? What tire information? I don't believe I gave any tire information beyond commenting on your comment regarding jacknifes. If short, fat tires were better choices, I would suspect you would see them on many more trailers. But, for some reason, we don't. Wonder why? There are RV owners out there spending TONS of money on the best tires they can get to be safe and not have blowouts. Exactly NONE of them end up with tires that are anything like those. Why would I care what their cornering stiffness is? I care if they are rated for the load that is on them WAY before I am worried about how it will fare at the next autocross. The ONLY place you see tires like those are in low capacity applications, small campers, snowmobile trailers and the like. I know from experience with that type of tire on a popup camper that they are not very durable. Because of their small diameter, they spin VERY fast on the highway and fail often. I know people that travel with 2 and 3 spares they are so bad.Your tire information is also quite wrong. Tires are softening springs under load and slip angle. How about your "guess" as to what their cornering stiffness is? I've measured them on a test machine so I know. I've also tested quite a few Sprint cup tires on the machine and on the tracks. Now go tell us all what "loose" and "tight" means. Bet you don't really know...
The guy also should criss cross the straps in an X configuration. That would really help keep keep it centered. The way the straps are now won't keep it centered for long with it bouncing around on a road.
I've run across advocates of this criss cross pattern a few times on this site and honestly it makes absolutely no sense to me and think it's likely a myth. The way I see it instead of adding any load security in would in fact reduce it...significantly. I see a few issues with criss crossing tie-downs, first is if one of the tie down pair breaks the extra length required for criss crossing enables the load to move that much more in the direction being pulled, an extra foot or two of tie down length could forseeably be the difference between losing the load over the side of the trailer or not. Second, criss crossing would provide little roll-over support or relatively much less than simply securing four corners of the load to their respective deck tie-down point minimizing tie-down length. Third, additional length equates to additional tie-down stretch (webbed) which would reduce centering integrity.
The only scenario I would expect criss crossing would be a benefit is if the structural integrity of the load is suspect and criss crossing is needed to pull it together instead of pull it apart.
We had the WSP in giving a class on the new laws which came out a few years back. Here equipment must be independently chained at each corner and any buckets must be on the deck and chained as well. For a backhoe, that means a minimum of 6 chains. Or a tractor with FEL, a minimum of 5 chains. Straps on equipment aren't legal here any more.
