can you guess what these things are??
   / can you guess what these things are?? #21
No bearing or bronze/Delrin bushing thru i.d. ?
   / can you guess what these things are?? #23
I actually turned out 3 pretty similar to these...mine have a deeper "vee" and fit into brackets I mounted on my car trailer...winch cable guides, in my case.
   / can you guess what these things are?? #24
Yes, they are for a bogey 15 amp blast master, push pull preamplifier thats coupled with a 18 inch triaxial mobil stage audio amplifiing super hederodine single needle dual channel vubalance meter.
   / can you guess what these things are?? #26
Wow!:shocked: Jim, you took the words right out of my mouth!:laughing:
How about a wacha-ma-jig for a two staged thingy-ma-bobber coupled with a single stage do-ma-flotchy?
Magicheater and zzbyv6 pretty much got it. Thomas was beating around the bush pretty close and LD1 was in there too,
I use it for the toplink pin on my attachments and it helps to center my quick hitch. I'm outfitting all of my stuff with them.
I'll post pics when I get home this afternoon.
Here's my box blade with the first one I had my brother build me. It works awesome. Now I don't have to be so perfectly lined up with my implements. Just get the hook close and this thing will center the quick hitch.
The dimensions are slightly different on this one compared to the new ones but this was a first try. The new ones will allow less side to side movement of the implement.
I have 4 other pieces of equipment that I'm going to equipment with these.
   / can you guess what these things are?? #29
I'm getting 273-1/2 made and using them the same as Firefighter's only I'm adding 100 ton hippozap to mine for extra strength.
Rob
   / can you guess what these things are?? #30
Your brother did nice work on them pieces:thumbsup:.
Got a kick at the sign in background("if you can't afford etc.").
If that doesn't get the point accross write it in blood.:laughing::D
Boone
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
WB 32in Excavator Digging Tooth Bucket (A55787)
WB 32in Excavator...
Step Ladder (A47477)
2021 Dodge Durango GT AWD SUV (A55758)
2021 Dodge Durango...
Hose Reel for Vacuum Truck (A53314)
Hose Reel for...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
