Angle Broom
   / Angle Broom #1
kcook
MI
Cub Lawn Tractor
Looking at a Angle Broom (used) as part of a purchase of a bobcat.
What other use's are there for one?
I know it will move some snow and clean off a driveway but can it detach my lawn?
Price is 1500
KC
   / Angle Broom #2
I use my angle broom to sweep the rocks out of my driveway in the spring after
winter plowing. Works very well. Need to set the brush height so the broom only slightly touches the grass. It does clean up the loose leaves and twigs that accumulate also.
   / Angle Broom
Will it detach the lawn?
KC
   / Angle Broom #4
I don't think it would work well for that purpose. If the broom rides too low, it will just flatten out the grass until it was slick and eventually tear it out, especially at higher rpms.
(mine only turns at 150 rpm and I keep it up high)
   / Angle Broom
Thanks for the reply!!
KC
   / Angle Broom #6
I watched a landscaping company clean up sand on a blacktop parking lot this week with a non rotating "broom". It didn't create the cloud of dust that is usually caused by the rotating "brush". As far as a rotating "brush", yes it will detatch your lawn quite nicely if the lawn isn't too wet.
   / Angle Broom
Thanks, I can get either.
KC
500BBL WHEELED...
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
2001 John Deere 6210 (A60462)
2001 John Deere...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
