Angle Broom
   / Angle Broom #1
kcook
MI
Cub Lawn Tractor
Looking at a Angle Broom (used) as part of a purchase of a bobcat.
What other use's are there for one?
I know it will move some snow and clean off a driveway but can it detach my lawn?
Price is 1500
KC
   / Angle Broom #2
I use my angle broom to sweep the rocks out of my driveway in the spring after
winter plowing. Works very well. Need to set the brush height so the broom only slightly touches the grass. It does clean up the loose leaves and twigs that accumulate also.
   / Angle Broom
Will it detach the lawn?
KC
   / Angle Broom #4
I don't think it would work well for that purpose. If the broom rides too low, it will just flatten out the grass until it was slick and eventually tear it out, especially at higher rpms.
(mine only turns at 150 rpm and I keep it up high)
   / Angle Broom
Thanks for the reply!!
KC
   / Angle Broom #6
I watched a landscaping company clean up sand on a blacktop parking lot this week with a non rotating "broom". It didn't create the cloud of dust that is usually caused by the rotating "brush". As far as a rotating "brush", yes it will detatch your lawn quite nicely if the lawn isn't too wet.
   / Angle Broom
Thanks, I can get either.
KC
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
