What to do with Bad Gas?
   / What to do with Bad Gas? #1
polo1665
Ohio
Branson 3510H, John Deere X750
Please forgive the seemingly stupid question I am about to ask.
We recently decided to start driving a car that has sat idle for the last 7 years. Needless to say the gas is no good, we started the vehicle and it ran very badly.
I was advised to run the vehicle out of gas, but after a short drive I lost my nerve and decided to siphon the gas from the tank. After doing this and refilling with fresh gas and injector cleaner, the car is running 100% better.
Now the question..........I siphoned about 14 gallons of gas out of this vehicle, what do I do with the bad gas? Can I add an additive to the gas (octane boost) to make it useable in my mower, or am I stuck with using it to get fires going? I've got 3 gas cans tied up with this crap.
Any advise or knowledge on the subject from the group would be appreciated.
Mark
   / What to do with Bad Gas? #2
What to not do with it..... don't add good gas to the bad assuming that the bad will get sufficiently diluted/good to use in an internal combustion engine...don't ask how I know.
Also, crazy as it sounds, I tried to use old gas to start a fire to burn some trash....didn't work...I could drop a flame on the "gas" soaked material...no flame propagation ..had to put new diesel on it to get a fire started.
   / What to do with Bad Gas? #3
Check with your local Fire Dept or local goverment. Many agencies have haz-mat recycling at regular periods for free. Much better than using it to kill weeds.
   / What to do with Bad Gas? #4
Mark
Strike a match? the smell will go away soon!!!!!:laughing:
   / What to do with Bad Gas? #5
Seriously--- I think this is the best idea..
J
   / What to do with Bad Gas? #6
That's a lot of gas and seven years is pretty old. Stale gas does not light by match in my experience.
Haz-mat recycling is a better idea than trying to burn it in your car a gallon or two per tankfull.
   / What to do with Bad Gas? #7
Do not feel bad. I have taken 150 gallons of bad gas out of a boat before. Its worthless. Call your local recycling center or haz mat folks like others said and make it go by by.
Chris
   / What to do with Bad Gas? #8
I would see if your dump or recycle center has a recovery tank. As I am a pyro by nature and burn piles of brush/stuff occasionally, I sometimes use old petroleum products to ignite it. Don't trust the statement that stale gas won't ignite unless you are unhappy with your eyebrows.
   / What to do with Bad Gas? #9
Chris
Ouch. That's a lot to dipose of.
The big one I need to work out is the disposal of around 40# of Mercury. The local haz-mat recycle will take it, but it's worth quite a bit of money and I don't want to just give it away for free.:(
   / What to do with Bad Gas? #10
Use instead of water next time you mix up and apply roundup.
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
NEW HOLLAND C345 SKID STEER (A52705)
NEW HOLLAND C345...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2020 BOBCAT T770 SKID STEER (A52705)
2020 BOBCAT T770...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
