What to do with Bad Gas?
   / What to do with Bad Gas?
Another thing you might look at is a product called "Start" made by the company which makes Stabil. Start your engines - fuel system revitalizer
Geez, your full of great info, Cyril.
Where were you when I started this thread?
This stuff wouldn't have worked for the Vette though, says for small engines.
Another question.........When premium gas goes bad, is it worse that bad regular gas?
Mark
   / What to do with Bad Gas? #62
Geez, your full of it, Cyril.
Mark
Mark,
careful there....
I think he might really give you some advice!!!!!
J
Mark,
careful there....
I think he might really give you some ill conceived advice!!!!!
J
Oh, I'm sure his heart is the right place, but I'll be careful if you say so.
Mark
   / What to do with Bad Gas? #64
Mark
I am sure it is...
and I am also sure he is :laughing: right now reading this exchange!!!
Cyril,
please do keep up the great advice and enjoy the banter!!!!
J
   / What to do with Bad Gas? #65
Mark
I was here, but what can I say...
...I'm slow sometimes.:laughing:
Actually, it wasn't until I read about the PRI-G and started responding about it and Stabil that it occured to me about Start. The owner of my local NAPA store told me about Start earlier this year when I was working on getting some older equipment back up and running. Generator, tiller, etc. It seems to work well. Granted, I had to pull and flush the tanks on this equipment and added the Start to the new fuel, but my tiller which has never run right since I got it started running perfect after about 5 minutes of use. Note that the tiller had sat for about 7 years since the last time I tried to get it running.
   / What to do with Bad Gas? #68
Mark
OK, going to take a stab at this, but I may be way off base so take this with a grain of salt.
Premium gas (higher octane) is less flamable than reguar gas. I would think that if old gas becomes less flamable then premium would be worse than regular over the same time span?
Man I can't type straight today. Lots of spelling corrections today (reversed letters).
The reason, as I understand it, that premium gas needs to be used in older vehicles is that the higher flamable gasolines of today ignite from pressure before the spark plug has fired (pre-ignition ping) when used in the older higher compression engines. Higher octane fuel or octane booster is used to ****** the flamability of the fuel to eliminate the pre-combustion and eliminating the problem.
   / What to do with Bad Gas? #69
Have you considered trying Pri-G? I've never tried it but heard good things about it. It claims to make old gas like new again.
PRI Advanced Fuel Treatments
:confused2: For the cost of a tank of gas you can restore a bunch of tanks of gas. ... b.b.but, how much do you have? What may be great if you have a lot of neglected cars, is not such a bargain in the case of sporadic need. There is an always fresh product on the market to serve the rare and incidental need [you have to use more, but its much cheaper and you end up with more gas]. For most of us this is a great opportunity to help others get rich.
larry
An excellent explanation, I had no idea.
Mark
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
NEW HOLLAND TS6.120 TRACTOR (A51406)
NEW HOLLAND...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNUSED LANDHONOR ABC-13-125A HYD BRUSH CUTTER (A54757)
UNUSED LANDHONOR...
JOB BOX W/ 100K X 20' NYLONG SLINGS (A54757)
JOB BOX W/ 100K X...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
