What to do with Bad Gas?
   / What to do with Bad Gas?
Another thing you might look at is a product called "Start" made by the company which makes Stabil. Start your engines - fuel system revitalizer
Geez, your full of great info, Cyril.
Where were you when I started this thread?
This stuff wouldn't have worked for the Vette though, says for small engines.
Another question.........When premium gas goes bad, is it worse that bad regular gas?
Mark
   / What to do with Bad Gas? #62
Geez, your full of it, Cyril.
Mark
Mark,
careful there....
I think he might really give you some advice!!!!!
J
Mark,
careful there....
I think he might really give you some ill conceived advice!!!!!
J
Oh, I'm sure his heart is the right place, but I'll be careful if you say so.
Mark
   / What to do with Bad Gas? #64
Mark
I am sure it is...
and I am also sure he is :laughing: right now reading this exchange!!!
Cyril,
please do keep up the great advice and enjoy the banter!!!!
J
   / What to do with Bad Gas? #65
Mark
I was here, but what can I say...
...I'm slow sometimes.:laughing:
Actually, it wasn't until I read about the PRI-G and started responding about it and Stabil that it occured to me about Start. The owner of my local NAPA store told me about Start earlier this year when I was working on getting some older equipment back up and running. Generator, tiller, etc. It seems to work well. Granted, I had to pull and flush the tanks on this equipment and added the Start to the new fuel, but my tiller which has never run right since I got it started running perfect after about 5 minutes of use. Note that the tiller had sat for about 7 years since the last time I tried to get it running.
   / What to do with Bad Gas? #68
Mark
OK, going to take a stab at this, but I may be way off base so take this with a grain of salt.
Premium gas (higher octane) is less flamable than reguar gas. I would think that if old gas becomes less flamable then premium would be worse than regular over the same time span?
Man I can't type straight today. Lots of spelling corrections today (reversed letters).
The reason, as I understand it, that premium gas needs to be used in older vehicles is that the higher flamable gasolines of today ignite from pressure before the spark plug has fired (pre-ignition ping) when used in the older higher compression engines. Higher octane fuel or octane booster is used to ****** the flamability of the fuel to eliminate the pre-combustion and eliminating the problem.
   / What to do with Bad Gas? #69
Have you considered trying Pri-G? I've never tried it but heard good things about it. It claims to make old gas like new again.
PRI Advanced Fuel Treatments
:confused2: For the cost of a tank of gas you can restore a bunch of tanks of gas. ... b.b.but, how much do you have? What may be great if you have a lot of neglected cars, is not such a bargain in the case of sporadic need. There is an always fresh product on the market to serve the rare and incidental need [you have to use more, but its much cheaper and you end up with more gas]. For most of us this is a great opportunity to help others get rich.
larry
An excellent explanation, I had no idea.
Mark
eyah, I kwno were your comnig form. I gto teh smae thign gogni on.
Mark
larry
I hadn't really looked into the price aspect, but I can sure see where you would be right. I fear that a lot of people are out there trying to make sure that I make other people rich. I probably shouldn't try helping them.
I'll look at it much more closely before purchasing anything. Mixing it with "fresh Gas" would seem to be the most cost effective way to deal with it.
Mark
Mark
   / What to do with Bad Gas? #73
Mark
Mark
In your case, mixing might be your best option as the vehicle ran good with the fuel replaced. For me with the tiller, I was having carb issues and added the Start to new fuel and my issues went away. Slightly different situation.
I have an air compressor which I will be looking at next. The fuel in it is only around 3 years old. Last time I tried to run it the plug with were creating an electrical storm over the engine and it ran, but poorly. It has a 20 gallon fuel tank which is about 1/2 full. Not sure yet what my plans are. I have a few other things to finish first.
   / What to do with Bad Gas? #74
I would just pour it over my hill[like I do about every spring],think I poured 15 gal or so over one of my hills this spring:laughing: Its good grass killer too.
   / What to do with Bad Gas? #75
Where do you guys come up with this "stuff" about premium unleaded gasoline being : slower burning, more carbon deposits and less flammable?
DEWFPO
   / What to do with Bad Gas? #76
Take the old gas to the local auto parts store or oil change place. They seem to all take old oil with no problem. I just took at least twenty gallons to a quick lube place yesterday. Some of it was gas, some used oil and some contaminated diesel fuel. They even helped me unload and pour it out. Then they tossed the containers for me. All for no charge.
Wow, I didn't realize that they would do that for you. Nice to know for future reference.
Mark
   / What to do with Bad Gas? #78
It wouldn't hurt to put in some carb & fuel inj cleaner to help clean the system. Plus it might help the old stuff to burn better.
   / What to do with Bad Gas? #79
When I have bad gas I excuse myself from the room for a moment. Aye carumba burritos!
For your fuel, if you can, take it to the local hazmat disposal. It's the best thing to do from a socially responsible point of view.
Now if it was me, cuz I am a redneck, I'd burn it, along with a good ole pile o' brush. If it don't go up easy, let the pile start and then have your pal pour it on, oh yeah!
   / What to do with Bad Gas? #80
No places I've ever been to in CA and CO will let you put fuel (gasoline) into their waste oil tanks.
DEWFPO
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
2016 John Deer 5075E (A60462)
2016 John Deer...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2015 FREIGHTLINER...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
