What to do with Bad Gas?
   / What to do with Bad Gas?
Another thing you might look at is a product called "Start" made by the company which makes Stabil. Start your engines - fuel system revitalizer
Geez, your full of great info, Cyril.
Where were you when I started this thread?
This stuff wouldn't have worked for the Vette though, says for small engines.
Another question.........When premium gas goes bad, is it worse that bad regular gas?
Mark
   / What to do with Bad Gas? #62
Geez, your full of it, Cyril.
Mark
Mark,
careful there....
I think he might really give you some advice!!!!!
J
Mark,
careful there....
I think he might really give you some ill conceived advice!!!!!
J
Oh, I'm sure his heart is the right place, but I'll be careful if you say so.
Mark
   / What to do with Bad Gas? #64
Mark
I am sure it is...
and I am also sure he is :laughing: right now reading this exchange!!!
Cyril,
please do keep up the great advice and enjoy the banter!!!!
J
   / What to do with Bad Gas? #65
Mark
I was here, but what can I say...
...I'm slow sometimes.:laughing:
Actually, it wasn't until I read about the PRI-G and started responding about it and Stabil that it occured to me about Start. The owner of my local NAPA store told me about Start earlier this year when I was working on getting some older equipment back up and running. Generator, tiller, etc. It seems to work well. Granted, I had to pull and flush the tanks on this equipment and added the Start to the new fuel, but my tiller which has never run right since I got it started running perfect after about 5 minutes of use. Note that the tiller had sat for about 7 years since the last time I tried to get it running.
   / What to do with Bad Gas? #68
Mark
OK, going to take a stab at this, but I may be way off base so take this with a grain of salt.
Premium gas (higher octane) is less flamable than reguar gas. I would think that if old gas becomes less flamable then premium would be worse than regular over the same time span?
Man I can't type straight today. Lots of spelling corrections today (reversed letters).
The reason, as I understand it, that premium gas needs to be used in older vehicles is that the higher flamable gasolines of today ignite from pressure before the spark plug has fired (pre-ignition ping) when used in the older higher compression engines. Higher octane fuel or octane booster is used to ****** the flamability of the fuel to eliminate the pre-combustion and eliminating the problem.
   / What to do with Bad Gas? #69
Have you considered trying Pri-G? I've never tried it but heard good things about it. It claims to make old gas like new again.
PRI Advanced Fuel Treatments
:confused2: For the cost of a tank of gas you can restore a bunch of tanks of gas. ... b.b.but, how much do you have? What may be great if you have a lot of neglected cars, is not such a bargain in the case of sporadic need. There is an always fresh product on the market to serve the rare and incidental need [you have to use more, but its much cheaper and you end up with more gas]. For most of us this is a great opportunity to help others get rich.
larry
An excellent explanation, I had no idea.
Mark
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
