Wet Disc Brakes
   / Wet Disc Brakes #1
funwithahoe
Gold Member
Does anyone know what is meant by"Wet Disc Brakes"?? Sounds heavy duty.
   / Wet Disc Brakes #2
I believe it refers to the fact that the brakes are inside the transmission assembly and submerged in oil.
   / Wet Disc Brakes #4
The brake "dust" also contaminates the hydraulic oil. Be sure to change the oil at recommended intervals. There should be a drain bolt at the bottom of each brake housing. Much of the grime is trapped there.
   / Wet Disc Brakes #6
Goes double for driving around with your brake on. :D
   / Wet Disc Brakes
Just occurred to me - How do they work - Can't be friction if they are submerged in transmission oil. Any pressure lock could leak over time??
   / Wet Disc Brakes #8
Sure can, like any wet clutch pack if you're familiar with that concept.
It's usually a sandwich of rotor plates and friction plates so there's much more contact area than a typical single dry disc to compensate for the loss of friction. When squeezed together by a piston, most of the oil shears off. The oil takes the place of air for cooling.
Google could probably tell you everything else you want to know about them. :)
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
UNUSED WOLVERINE TDB-11-78W 78" BUCKET (A57193)
UNUSED WOLVERINE...
UNUSED FUTURE D-PDQ 47" LAND LEVELER (A57193)
UNUSED FUTURE...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
(16) 12" CHANNEL IRON (A57192)
(16) 12" CHANNEL...
2014 Ford F-250 Ext. Cab Pickup Truck (A54814)
2014 Ford F-250...
