Wet Disc Brakes
   / Wet Disc Brakes #1
funwithahoe
Does anyone know what is meant by"Wet Disc Brakes"?? Sounds heavy duty.
   / Wet Disc Brakes #2
I believe it refers to the fact that the brakes are inside the transmission assembly and submerged in oil.
   / Wet Disc Brakes #4
The brake "dust" also contaminates the hydraulic oil. Be sure to change the oil at recommended intervals. There should be a drain bolt at the bottom of each brake housing. Much of the grime is trapped there.
   / Wet Disc Brakes #6
Goes double for driving around with your brake on. :D
   / Wet Disc Brakes
Just occurred to me - How do they work - Can't be friction if they are submerged in transmission oil. Any pressure lock could leak over time??
   / Wet Disc Brakes #8
Sure can, like any wet clutch pack if you're familiar with that concept.
It's usually a sandwich of rotor plates and friction plates so there's much more contact area than a typical single dry disc to compensate for the loss of friction. When squeezed together by a piston, most of the oil shears off. The oil takes the place of air for cooling.
Google could probably tell you everything else you want to know about them. :)
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
204549 (A52707)
204549 (A52707)
202473 (A54757)
202473 (A54757)
TANK MANIFOLD (A55745)
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
