Wet Disc Brakes
   / Wet Disc Brakes #1
funwithahoe
Gold Member
Does anyone know what is meant by"Wet Disc Brakes"?? Sounds heavy duty.
   / Wet Disc Brakes #2
I believe it refers to the fact that the brakes are inside the transmission assembly and submerged in oil.
   / Wet Disc Brakes #4
The brake "dust" also contaminates the hydraulic oil. Be sure to change the oil at recommended intervals. There should be a drain bolt at the bottom of each brake housing. Much of the grime is trapped there.
   / Wet Disc Brakes #6
Goes double for driving around with your brake on. :D
   / Wet Disc Brakes
Just occurred to me - How do they work - Can't be friction if they are submerged in transmission oil. Any pressure lock could leak over time??
   / Wet Disc Brakes #8
Sure can, like any wet clutch pack if you're familiar with that concept.
It's usually a sandwich of rotor plates and friction plates so there's much more contact area than a typical single dry disc to compensate for the loss of friction. When squeezed together by a piston, most of the oil shears off. The oil takes the place of air for cooling.
Google could probably tell you everything else you want to know about them. :)
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
Hercules Gun Safe (A55853)
Hercules Gun Safe...
2014 Electric Cart (A53424)
2014 Electric Cart...
Deere 35P (A53317)
Deere 35P (A53317)
8ft Flatbed Truck Body with Axle (A55852)
8ft Flatbed Truck...
