Wet Disc Brakes
   / Wet Disc Brakes #1
funwithahoe
Does anyone know what is meant by"Wet Disc Brakes"?? Sounds heavy duty.
   / Wet Disc Brakes #2
I believe it refers to the fact that the brakes are inside the transmission assembly and submerged in oil.
   / Wet Disc Brakes #4
The brake "dust" also contaminates the hydraulic oil. Be sure to change the oil at recommended intervals. There should be a drain bolt at the bottom of each brake housing. Much of the grime is trapped there.
   / Wet Disc Brakes #6
Goes double for driving around with your brake on. :D
   / Wet Disc Brakes
Just occurred to me - How do they work - Can't be friction if they are submerged in transmission oil. Any pressure lock could leak over time??
   / Wet Disc Brakes #8
Sure can, like any wet clutch pack if you're familiar with that concept.
It's usually a sandwich of rotor plates and friction plates so there's much more contact area than a typical single dry disc to compensate for the loss of friction. When squeezed together by a piston, most of the oil shears off. The oil takes the place of air for cooling.
Google could probably tell you everything else you want to know about them. :)
2014 FREIGHTLINER DAYCAB ROAD TRACTOR (A57192)
2014 FREIGHTLINER...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
CLUB CAR (A55758)
CLUB CAR (A55758)
205196 (A52706)
205196 (A52706)
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
