Rafter size for 16ft Span
   / Rafter size for 16ft Span #1
ustmd
Manor, TX (outside of Austin)
Kioti CK27 HST
Hiya,
Looking for information/feedback.
Finally, I am going to build the workshop.
I am looking at having a 16 ft span on on a simple shed roof with a 2/12 pitch.
I am in Central texas, so there is no snow load.
I am trying to decide on the size of the rafters and spacing and I am looking for feedback from people who have experience with their buildings.
Depending on the tables, I look at, I can do 2x8, 2x10 or 2x12. My preference would be to stay at 24 oc, but I am willing to drop to 16 oc to add strength and drop to 2x8s (general easy of handling).
Any feedback would be appreciated.
Thanks
   / Rafter size for 16ft Span #2
What are you going to use for decking/roofing?
if I were building it...I would go with 2x8 16"oc...then deck with 1/2" or better plywood and a torch down bitumen roofing...OR...2x8 16"oc with 1x4 lattice 24" oc and use 5V metal roofing...
how do you intend to add an overhang on the ends? hung barge? or do your beams extend ?
   / Rafter size for 16ft Span #3
You may not have a snow load to contend with but don not forget to insulate.
   / Rafter size for 16ft Span #4
Can you get away with a 2/12 pitch there?
Even without a snow load, I am surprised you can build that flat.
/Pine,
I am thinking about putting Galvalume Metal over a 1/2 radiant barrier sheathing.
Transit,
Definitely on the insulation--I am considering doing spray foamed, but that would be another task I would have to sub out.
Tanks
   / Rafter size for 16ft Span #6
sounds good...still curious about the overhangs...
if you can't get long enough material scabbing tails may be your only option ??
That is part of my problem is sizing the materials. To keep it simple, I would prefer to just let the rafter run over for the over hang, but I may not be able to get stock that long.
   / Rafter size for 16ft Span #8
I've seen 2x12's in 20ft lenghts, so I assume you could get 20ft 2x8's too. But I bet they're proud of 'em!
   / Rafter size for 16ft Span #9
2x8 will come in 20' lengths. Ive seen 2x6 in 20 foot lengths. 2x8 may be pushing it for that span. they will definitely deflect but they wont break/fail. In your area they probably have southern pine which is stronger than our spruce/fir we have on the northeast. Doug fir will also be stronger if you can get your hands on that.
   / Rafter size for 16ft Span #10
If you go 2x8, your OC should be 16" as you stated you were willing to do.
If you go 2x10, your OC would be fine at 24", as 16" would be a bit over build, given you have no snow load. Snow or not, I much prefer a 4/12 for the look. Go 5/15 and it virtually assures the ability to have a storage loft in all or part of the building. What a difference in practical storage space a loft makes. It is about the cheapest square foot storage you can build.
Your plan doesn't call for sheathing the roof, as I understand it. If you decide to sheath, do use plywood/OSB clips for 24" on center to avoid deflection.
   / Rafter size for 16ft Span #11
Southern pine/southern yellow pine (SYP) is used primarily in less expensive plywood sheathing veneers. It is far less structural than your spruce /fir and as you said, douglas fir is the most structural North American construction softwood on the market. DF Grades of 2x6 through 2x14 are from least to best: #2, #1, select structural (SEL STR) and SEL STR DENSE. All but the dense grade are generally mixed in a given unit of #2 & BETTER. Special order DF stock will provide the DENSE grade stamp and all grades from a specialty mill are available up to 28'-30' in length. BIG $$$$. This is why the glu-lam and composite joist market was developed.
   / Rafter size for 16ft Span #12
Consider checking out the cost of an engineered truss. You may just be able to get one to approximate your desired shape. :thumbsup:
Also check up on wind loading. Those specifications may have been altered quite recently.:D
   / Rafter size for 16ft Span #13
Although a shorter span, the principles apply. I had a disaster of a small barn i inherited with the place. It too was an 18' span, with a 2/12 pitch. It was saggy and leaked no matter what repairs were made. Enough!! We did a tear off of the shingles, sheathing and pulled all the rafters off. I reversed the pitch of the roof. I extended the wall height an additional 2 feet which allowed me to go to 5/12. I reclaimed the old rafters, and cut birdsmouth, upper and lower. I have 9" over hangs with rafter cuts. I faced them with 1 by.
The added pitch and height allowed me to put a small loft at both ends for storage. It is all shingled as of last night. The deck is OSB with good tar paper underneath and drip edge all around.
This week, I will side it with vinyl, mostly because I reclaimed the vinyl that was on it and I won't have to paint, ever. Might have preferred steel, but this project was a re-do and re-build and I have very few dollars in the project.
Hopefully some of these pix might give you a few ideas. Best regards on your new barn/shed.
   / Rafter size for 16ft Span #14
FWIW...
#1 dense yellow pine is (pound for pound) stronger than steel...
Almost all structural members used in trusses of any kind in the S.E. US are made with #1 dense SYP...
Thanks for the feedback, I knew I could count on you guys :thumbsup:.
I am thinking I am going to go with 2x10 on 24 oc or maybe even 2x12 (for the extra insulation space)--though hauling 85 lbs rafters onto the studs is not exciting me.
I was going to pursue a truss or an engineered rafter, but the nearest lumber yard near me just closed. Since I am not in the tradesm, I am left with big box stores, unless I am willing to go 30-50 miles.
While the 2x8 might work, if the structure of this building has issues, the wife will NEVER let me hear the end of it.
Just to be clear, I am planning on sheathing with radiant foil backed OSB, tar paper, drip edge and metal roofing.
   / Rafter size for 16ft Span #16
Don't forget light guage galvanized steel rafters, cut to order. I just
bought 18-ft 2x8x16ga for $22 each. They are very stiff, perfectly
straight, and cut to exactly 18.00' long. Impervious to the weather, too.
This is for my 17'x19' building. I will make trusses and go with a 4:12
pitch steel roof.
   / Rafter size for 16ft Span #17
Don't disregard engineered trusses just because you're not in the trade.
Search for truss manufacturing companies (google or yellow pages) near you.
I got the trusses for my 24' x 24' studio building from a truss manufacturer. Cost was less than what stick-built would have been because they can engineer a solution to use smaller lumber than you will have to use for non-engineered stick-built.
   / Rafter size for 16ft Span #18
How about those wood "I" beams for long spans. When my house was built they used these for the floor joists and they covered 14-16' spans. I'm thinking about making my own for my garage/shop project but researching to see what the down side might be...
   / Rafter size for 16ft Span #19
unless you use 3/4 osb...there will be a good amount of deflection when spanning rafters set at 24" oc...although is is structurally sound using 1/2" sheathing I would not use anything less than 5/8"
Also something to check into...if the metal roofing is laid directly on top of the sheathing (radiant barrier) there may be a condensation issue...
All metal roofs sweat (on the under side) when temperature and humidity conditions are right...
Good point about the roof sweating--I will need to check into it. I am wondering if a fur it up on some 1x stock to creat an air space with venting is I can get around it.
Due to the urging of several on this thread, I am looking at trusses. I have Don at 84lumber working me up a truss and quote--as well as having calls out to a few other manufacturers. Hope to hear back today.
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
207275 (A52708)
207275 (A52708)
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
