Rookie farmer gets first Hay Baled - yippee !
   / Rookie farmer gets first Hay Baled - yippee ! #11
Congratulations, I am a newbie also and have only done it a few years. There is nothing better than to look at the barn with hay overflowing. Do you have animals or are you selling? We have horses and goats? Making your own off of your own land is a job well done. What type of equipment do you have? I have a Ford 641 tractor, Ford 501 Sickle Bar, Ford Rake and an Oliver 720 square baler.
Hi Hobby Farmer, We have 3 Icelandic horses, by the time I get it all off (if all goes well) I will have some to sell off too.
Equipment: 2008 Montana C5264 Tractor, 52 HP , 4wd, FEL
70's/80's New Holland 479 Haybine/Conditioner
70's/80's New Holland 310 hayliner Square Baler
50's/60's New Holland Side Rake
   / Rookie farmer gets first Hay Baled - yippee ! #13
Baler has 2 sections of Ramp/chute (no turns) that I have tilting up (as if they should be resting on a Wagon), If not tilted up otherwise they drag on the ground . No kicker
Maybe thats better than a 4' drop ?. Ive tried adjusting the length of the chains that hold the ramp sections, however as soon as those sections get to be too flat (2' parallel to the ground) , they end up folding back and dragging any way.
Im away from the Fram just now so no pics
You tilt your ramp up only when you need to load up onto a wagon. You tilt your ramp level or somewhat below level to drop your bales gently on the ground. Sounds like you need to find a new mounting point for your ramp chains that will keep your ramps lower.
yes, I beleive you are correct, Ill keep playing with it
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2024 Quality Steel Deck Over Tilt Trailer (A59814)
2024 Quality Steel...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
2000 Morbark Towable Brush Chipper (A59228)
2000 Morbark...
Flatbed Truck (A55973)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
