Pics of my new Kubota L3940
   / Pics of my new Kubota L3940 #21
Philip (or any other HST + Cruise Control owners), have you done this?: I was using my FEL to lift something up & over the sides of & into my utility trailer, & when I was done went to shift from L to M range to back away faster ... but hit the cruise bar instead, still in forward :eek: Caught it real quick, but not quick enough as it put a little crunch bend in my trailer's fender. That fender was no match for the tractor :laughing:
There is a whole thread on embarrassing moments on tractors, so you are not alone. I routinely use four different tractors of three different makes, one of which is a geared unit, you would not believe the mental gymnastics I go through some times.
http://www.tractorbynet.com/forums/owning-operating/170996-embarrissing-tractor-moments.html
   / Pics of my new Kubota L3940 #22
Try using the HS/DS two speed high/low pump selector on the left side of the steering column for quick simple speed changes instead of the low/medium/high gearbox selection? Operate full FEL in low, emply FEL in high. No, luckly I have not done that. Thanks for the warning! Philip.
   / Pics of my new Kubota L3940 #24
No front weights.
I have a 6' brush bull and a 88" Alamo SHD flail. It handles both great.
Mine does fine on flat ground with my RCR2672, but gets a little light in the front going up steep inclines.
   / Pics of my new Kubota L3940 #25
That can happen. Just make sure you don't have the top link so tight that it is lifting the back of the mower.
Philip, TripleR, or any other Grand L owners ... I think I remember reading where one of you, or somebody on this site, is using the two ROPS welded-on forward-facing nuts, for lights maybe it was?
Anybody remember the bolt size for those nuts? Are they metric? Thread size?
(My L3940 is ~6 miles away, long round trip just to look before going to Home Deopt :))
Thank you ...
   / Pics of my new Kubota L3940 #27
I have a hydraulic top link which makes it really east to adjust with each implement, so when bush hogging, I have it loose to allow the weight to be on the tail wheel as per manual, but can "tighten" it up to back up and mow over ditches and ledges without slinging dirt. I also tilt the back up and back into heavy brush sometimes. I really like the ability to adjust without dismounting.
   / Pics of my new Kubota L3940 #28
Thank you ...
I just used thru bolt and nut with oversized washers. That would be a big bolt to fit thru your light clamp if you intend to use the nut in rops. Philip.
Sorry ... I'm not using the nuts to mount lights.
I'm making a plywood roof & want to use those two nuts to secure diagonal roof supports.
   / Pics of my new Kubota L3940 #30
Be sure to send us pictures of the roof/canopy. I've been thinking of doing the same.
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
1993 Mack RD688S Dump Truck, VIN # 2M2P267Y5PC014675 (A51572)
1993 Mack RD688S...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
