My Ride-on Tracked dumper
/ My Ride-on Tracked dumper
Not much to show. Had a township official plan that indicates I have some Primary Aggregate on my property so I went digging this weekend. Mostly found bolders but will dig further into the hill side. Anyway on the way home I picked up 100 feet of 6" conveyor belting to use for the tracks. ($150+tax). Yes there will be a drive wheel. Its the next hurdle I need to tackle. Probably need to get a couple of 12inch dia round plates 1/2 inch cut so I can make some drive gears.
I will be busy much of the next 3 weeks so expect slow progess.
Progress is slow. Too much going on and its been Cooking Hot up here in Toronto, Canada. Anyway I had a chance to put 6 hours into it today. Previously I machined some Weld on Hubs to fit the tight confines of the rear drives. These assemblies will be Welded onto the back of the track frames and braced with some 1/4 wall 2.5 inch angle. I will be cutting 9 teeth into the wheels which are 2x1/4 inch plate or 1/2 inch thick when welded together after teeth cut. I off on vacation for a couple of weeks so its going to be slow progress.
/ My Ride-on Tracked dumper #43
Not wanting to burst your bubble, BUT, I hope you aren't in a hurry using this. I have a Yanmar tracked dumper. It has a 10hp Yanmar diesel. Ground speed is 3mph empty. It is about 1/3 the size of your machine and made of much lighter material.
So far my bubble is still intact. Your Yanmar has twice the operating weight at 1,600 lbs and 1/2 Horse Power of my machine. 3mph is a good speed for something with no suspension and likely limited for operator saftey. Your unit is 9 feet long but only 3 ft wide. I am aming for 4'x8' My 12hp Kubota subcompact at 7mph is too fast for my back. I am actually counting on my tracked dumper to work in the snow with a track width of 14.5 inches.
Found one day to work on the tracked dumper. Installed one motor assembly and mocked up a track. Approx. 17 1/2 feet and will require 60 feet of steel for each track.
Progress seems slow but hopefully things will come together soon. A ton of work making up track shoes, making drive wheels. I have ordered 500 sets of nuts, bolts, washers and lock washers for the tracks. Not counting welding supplies, I am into my tracks to the tune of $400 now. I have upgraded to a 10 gallon Hydraulic tank from an earlier 5 gallon. Getting difficult to package everything so I am going up and up. At 4 feet wide most of the weight will be within 3 feet of ground but I will be sitting about 42 inches off the ground so a ROPS system will be a must. I have made up about 30 track shoes with another 90 to go.
/ My Ride-on Tracked dumper #49
Looking good Dave. :thumbsup:
That's one of the hardest things for me on a project like you're doing...the manotony of making the same pieces over and over. :(
Please take lots of pix of the track assembly as I'm having difficulty picturing how the track is going to be assembled.
Have you given thought to adding carrier wheels for the top of the track? With the length and potential weight, one or two may not be a bad choice.
/ My Ride-on Tracked dumper #50
So are you just using that rubber for the track and putting the steel underneith for the drive? If so, you may want some way of adding tread to the track so you wont be sliding if the ground is wet or icy.
Each track consists of 2 x 6in conveyor belting tied together with these track plates with integrated guides that run between the tires. These plates go between the belting and the ground, so I should have no issues with traction, except for any side sliping on ice. The track make up is very similar to a J5 Bombadier or muskeg tractor, except l will be running dual tires so the track locators will ride between the tires, not on the outside as in single tire applications. As well I will be adding additional pieces to ensure the tracks stay on during turns as tracks have a way of riding up on pnematic tires (especially if low on air). Just to get the tracks completed, I have 320 more holes to drill, 160 45degree cuts to make, 80 x 5 minutes of deburring on each track shoe, about 4 hours of grinding and welding on the drive gears and painting all 120 track shoes. Then I need to make up a jig to space out the shoes on the belting. This project is tying up both my garage and shed so I can do nothing else until it is finished.
/ My Ride-on Tracked dumper #52
David:
You are a patient and determined man. I'm with Cyril in that the monotony of making the same part over and over again would be my downfall.
/ My Ride-on Tracked dumper #53
Okay, that makes sence. :thumbsup: Sounds like you got your work cut out for you. :):thumbsup:
/ My Ride-on Tracked dumper #54
Sir
I am also up in Toronto. aka Uxbridge. I will try to keep track of the progress as I also built a small tracked vehicle.
Craig Clayton
/ My Ride-on Tracked dumper #55
Sir
Craig Clayton
You can't just casually mention that you build a small tracked vehicle without giving more details!!!
Pictures?
How big?
What did you use for tracks?
What's it powered by?
What do you use it for?
I am with Iplayfarmer. tell us more about it, when was it completed, what problems did you have with it and how were they fixed.......As far as the monotony, I usually get a system going where I am doing two things at once, like with a Horizontal bandsaw I can put a piece on and while it is cutting I can grind the previously made piece. I am a good day-dreamer so I have already put a 100 hours on the tracked vehicle and its not even made yet.
/ My Ride-on Tracked dumper #57
Sir
Craig Clayton
Pictures?
How big?
+1 on seeing pix and getting info.:thumbsup:
...and you have the OPs blessing so no excuses about not wanting to hijack the thread.:laughing::laughing:
So let's see those pix. :thumbsup: :thumbsup:
/ My Ride-on Tracked dumper #58
...I am a good day-dreamer so I have already put a 100 hours on the tracked vehicle and its not even made yet.
I can relate to daydreaming. Usually before I start a project I have spent hours building and rebuilding in my head. The fun part is when the real deal comes out looking like what I had imagined.
/ My Ride-on Tracked dumper #59
Hey Dave,
Just an idea that occurred to me. Crimping (or splaying) either the ends or the center of the track cleats might provide a small amount of sideways traction. That or notching them with an angle grinder.
/ My Ride-on Tracked dumper #60
To Iplayfarmer
The small tracked vehicle is a 1/6 scale of a 450 B Case crawler tractor. The entire tracked assembly drives. It is powered by electric wiper motors, I made the entire track to scale forming the groussers , idlers drive gears ,sub frame etc. If the sheet metal was to be finished it would look like the real thing. Just because it is smaller the detail and quality that I put in is very high. At the time I wrote to the Case company about my project and they wished me success. So I understand what a half scale track vehicle should entail. Right now it is under my bench collecting dust.
I now also play farmer which has equipment big enough to ride on or roll over. If could post pics if any one was interested.
Craig Clayton
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A60432)
UNUSED SDLANCH...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
Deere 410L (A53317)
Deere 410L (A53317)
CH and E 2909T 6in Towable Dewatering Pump (A59228)
CH and E 2909T 6in...
