My home built no-till seed drill
/ My home built no-till seed drill #1
spurlocktool
N. California
Kubota BX1500, BX2230
I have a 2 acre hillside no-till orchard that I seed with a cool weather legume mix each fall, then flail mow in the late spring for a mulch. I've been sowing by cutting shallow furrows with a spring tooth harrow, then hand-crank broadcasting and dragging to cover. It has always worked but lots of seed remains on the surface and is wasted. So I've finally built my own seed drill onto a modified disc harrow.
The heart of the machine is the seed metering system which uses neoprene blade outboard motor impellers running inside a 2 1/2" PVC pipe to carry seed from each input hole down to an output hole in even amounts and with no seed damage (I used a rigid rotor on an earlier prototype and found it broke too much seed). This new system works great in tests so far. It's a bit complicated to build, but if anyone is interested I have posted pictures here: Home built seed drill
Click on each picture to see a title and description, or click on sideshow.
I had to use only one gang of the two gang offset disc to lighten it enough to use on my compact Kubota BX1500. The single gang disc is not ideal because it pulls to one side, so on side slopes I need to only seed one direction or it wants to run off track downhill. Ideally a two gang offset disc can be used, modified so front and rear discs are essentially in one track and offset very little to make a narrow groove in the soil.
For tilled ground, depth control wheels could be added to limit cutting depth. But for my dry California fall soil it cuts about right on its own. I will follow seeding with a ring roller to pack the soil, but a small cultipacker type roller could be used instead of the scrapers I've made. This would set cutting depth as well as pack the seed.
The seed metering system works so well I just wanted to share it in case anyone else wants to adapt it to their needs. It could be run by electric motor instead of ground-driven and added to other implements or even a spring tooth harrow.
/ My home built no-till seed drill #2
That is an impressive home-built project. You have demonstrated some great skills and ingenuity.
Nice job.
/ My home built no-till seed drill #3
Great job. Thanks for sharing.:thumbsup::thumbsup:
JC:)
/ My home built no-till seed drill #6
awesome! Do you think it could be modified for grass seed ?
I don't think it would be suited to grass seed, since small seed needs to be planted very shallow. Also you would want complete coverage, not just rows of grass. A harrow followed by hand or tractor broadcasting then dragging to cover would probably be best for grass.
/ My home built no-till seed drill #11
Sorry, I don't have any video at the moment. What aspect of it would you like to see in video?
How it leaves the field behind, in what conditions you use it, the flow of the dirt over the disks and the backfillers, seed disposal of you home made camshaft seeding unit, etcetera... :)
/ My home built no-till seed drill #12
Third post since 2007? Common' man! You've got the kind of talent that TBS needs! Don't be a stranger! Beautiful build! ~Scotty
/ My home built no-till seed drill #13
WOW, This is a great post. The seed drill looks good. I am wanting a seed drill for our ranch. We were given one but it is all rusted out. The seed cups are really rusted bad. This just might be the ticket to rebuilding it with your seed tube idea.
Cheers,
Mark
WOW, This is a great post. The seed drill looks good. I am wanting a seed drill for our ranch. We were given one but it is all rusted out. The seed cups are really rusted bad. This just might be the ticket to rebuilding it with your seed tube idea. Does the polyethylene make good bearings riding inside the PVC? Will it get to hot and melt?
Cheers,
Mark
Thanks to everyone for the kind words. I will try to get around to posting a few other of my contraptions.
Mark, there shouldn't be a heating problem with the polyethylene since the discs fit the shaft freely and rpm is very slow, maybe around 30. I made the discs with a hole saw, then finished the outer diameter on a lathe for a light press fit in the PVC. Then bored the 7/8" hole while still in the lathe. So the poly discs are stationary in the PVC, and the 7/8" shaft rotates freely in them.
I've used this material for plain bearings before with no problems. It tolerates dust and is slippery and self lubricating in light load slow speed applications. The 7/8" shaft has a flanged ball bearing on the right (driven) end to take the side force of the drive chain. But the left end has only a 1" thick poly disc. If that were to wear I can easily replace it with another ball bearing, and at that point wear in the other discs would not matter. I'll try to post a video tomorrow.
/ My home built no-till seed drill #17
Uber cool!! Do you have a source and cost for the impellers?
Yes, I used impeller #18-3017 made by Engine and Drive Parts | Teleflex Marine. (If you click on each of the thumbnail photos in my album individually, they open larger and have expanatory text below, this impeller info is there.) These things are made in many sizes, numbers of blades, widths, shaft hole dimensions, etc. The one I used is about 1 1/4" wide and not quite 1/8" smaller OD than the ID of the 2 1/2" sch 40 PVC. If you google "18-3017 impeller" you'll find lots of suppliers and prices around $12-$16. Here's one: Amazon.com: Sierra 18-3017 Mercury/Mariner/Chrysler/Force Impeller: Sports & Outdoors
Have fun!
OK guys, I've posted a video here: Photo Sharing by MyPhotoAlbum :: billspurlock's MyPhotoAlbum Gallery :: Home built seed drill
It's about 2 minutes of video showing details of a seed metering prototype model as well as action shots of the drill in use. Most of it has narration so turn up your sound.
The legume mix cover crop seed I am using wants to be buried about 1-2" deep, and you can see that's about what I'm getting in my untilled dry ground. Harder ground would require some weight, while tilled or damp soil or smaller seed would require wheels or some such to limit depth of cut. This is our dry season here in California, so in October I will spread compost, then drill in the seed. I have very limited water (basically a dry farmed orchard except for a bit of drip irrigation), so I depend upon timely fall rains to get the cover crop up. I'll post results of the full scale planting test then.
In the meantime I'm happy to provide additional details or pictures so don't hesitate to ask.
/ My home built no-till seed drill #20
I gotta say, I have no need for this type of machine, but I do have need of those type of skills. WOW! Nice work, on both the design and construction. Looks like you thought of everything.
How long from the light bulb idea, to the finished project?
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
Kubota L4701 (A53317)
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
yellow ball Trailer (A56859)
yellow ball...
1993 Baja 29ft. Boat w Tri-Axle Boat Trailer. (A59231)
1993 Baja 29ft...
