1/4" Valve Haters---Read This
   / 1/4" Valve Haters---Read This
Based on your description, you have the QI model. You can still be wrong even at age 64.
If you think I have QI ---Good for You---I have no problem with that:thumbsup:[/B]
   / 1/4" Valve Haters---Read This #22
EZ guys geez one of the things that makes this forum nice is that everyone is polite - Well except Diez.
   / 1/4" Valve Haters---Read This #23
REALLY:(
I am 64 years old and I have owned, no less, then twenty tractors! I think I know how a tractor lift system works.
First--My post is intended to possibly help someone that dislikes the QI system. Read my post again:thumbsup:
Second--It makes no difference if I pull the leaver to me or away because there are NO stops, other then the adjustable ones that have only ONE STEP.
Idling, or wide open, the lift works the same. I can raise the implement slow or rapid, 1/16" or 2" depending on how fast I move the leaver.
If you think I have QI ---Good for You---I have no problem with that:laughing:
Take a picture of the control and post it on here. That should settle it.
   / 1/4" Valve Haters---Read This #24
EZ guys geez one of the things that makes this forum nice is that everyone is polite.
Agree completely.
I can understand the confusion on the QI as the different models have different set ups. Some have adjustable stops and some don't, some work OK and some just so-so. Yes, I am one of the haters.
   / 1/4" Valve Haters---Read This #25
I believe Giles has position control. I thank him for sharing his oddity and giving hope to those who just don't like the QI system that it might be a simple change to convert a QI to postion control. My B7200 had postion control and my B2620 has QI. Unfortunatley I never compared the two when I had them both at the same time to see what was different between them. I think this thread got a little derailed by all the QI setup questions. If Giles hasn't been run off I wouldn't mind seeing some pics of his rig so maybe we can see what is involved with converting a QI to postion control.
Thanks Giles for sharing, :thumbsup:
   / 1/4" Valve Haters---Read This #26
I am inclined to agree. I am also in my 60's and have driven tractors from an early age and certainly know the difference regardless of what the logo on a control shows. I have tractors with both.
Retrofit may be possible on certain models since some variations within that model has position control such as in the Bxx30 whereas the Bxx20 doesn't. This "may" not be possible in the BX, but if it is, sign me up.
TripleR and BrierPatch---THANKS for appreciating what My post is about:thumbsup:
I have made photos but have never posted a picture---I am working on that now and hope to have them on line soon.
I don't believe a small "conflict" like this is going to discourage my participation in this forum.
One on my life's pleasures is to help people and I feel that this post just might do that.
As I stated, Something may have been changed, done away with, or modified to my B2320.
If I live to be 90 I stand to be corrected--I learn something new almost every day:D
   / 1/4" Valve Haters---Read This #28
I am glad you will be staying around as I have really learned a lot from the knowledgeable people here.
I retired three years ago after 32 years on the job and to the day I left, I was committed to improving my performance and knowledge base.
I learn something new here all the time.
Posting pictures is fairly easy once you get it to the right size.
Here is my attempt to post pictures of my B2320 Lift Control---Hope it works--if not will try again.
I have more if needed
   / 1/4" Valve Haters---Read This #30
Please-Please-Please.....Keep it going....Being a Greenhorn to this Tractor/lifter/digger stuff is very informative....
I have the same B2320 and today was first time using 3PH with new Box Blade behind it.....QIV was not even in my vocabulary till now.....Something else to sit back, read and learn....:thumbsup:
LINDE H80D FORKLIFT (A50854)
LINDE H80D...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
